06-25-2009, 08:04 AM | #1 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
| too high
I think my crawler sits too high what should i do to make it lower? smaller shocks these are 4" losi shocks. any comments would be awesome thanks keith. Last edited by rockerrc; 06-25-2009 at 08:10 AM. |
06-25-2009, 08:18 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
Limit your shocks, put either fuel line or a spacer on the shock piston inside the shock and it will lower your ride.
06-25-2009, 08:25 AM | #3 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
move the rear shocks in closer, that will lower the rear, won't affect torque twist. It will still need spacers or fuel line in the shocks though.
06-25-2009, 08:41 AM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
run a droop set up,
06-25-2009, 09:12 AM | #5 |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
Angle those rear shocks forward quite a bit more and stiffen up the springs to compensate for the angle.
06-25-2009, 09:20 AM | #6 |
Newbie Join Date: Jun 2009 Location: Puyallup
| run it droop
06-25-2009, 09:42 AM | #7 |
How do I run a droop system just take the springs off and put the fuel line on it?
06-25-2009, 10:13 AM | #8 |
Rock Stacker Join Date: Jun 2009 Location: Austin
rebuild the shocks with tubing/spacer inside the shock housing.
