Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Fab questions
Old 11-07-2005, 01:38 PM   #1
Default Fab questions
1. I haven't done much metal fab and I want to put a round flat spot on one of the edges of an aluminum hex bar. Without going into too much detail, I am mounting a spacer on one of the corners and need to know what type of cutter/bit to use. Would a forcener bit work? Or is there a mill cutter/bit that would work better? I will be using a drill press and a cross vise.
2. Also, what is everyone using to notch the ends of tubing for a cleaner joint when building a tube chassis?
3. Is it possible to solder/braze aluminum rod together? Nothing really structural just to link 2 pieces together for bracing instead of screws.
NoOb is offline   Reply With Quote
Old 11-07-2005, 10:00 PM   #2
Wow, with over 22 views you'd think someone would have some knowledge on this subject.
Old 11-07-2005, 10:06 PM   #3
Ace
Sounds like you want a counter bore in the side of the hex to fit a round spacer into?
Aluminum is relatively soft and woodworking bits can usually be used to cut it...
That said are forsner bits made that small (I'm assuming you want about a .250" bore)
The proper bit would be a center cutting endmill in your drill press.
Brazing aluminum:
I've had good luck with "alumiweld" for brazing (soldering) aluminum. I just use a propane torch.
Ace is offline   Reply With Quote
Old 11-07-2005, 10:38 PM   #4
Thanks ACE!
Old 11-08-2005, 02:47 AM   #5
I have no clue what you are asking for. I do understand the tube notching ?. I use a 6" grinding wheel to miter tubing. But I weld not braze.
rckjeep is offline   Reply With Quote
Old 11-08-2005, 08:12 AM   #6
this is basically what I want to do.
