Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Battery mah question
Old 07-09-2009, 10:03 AM   #1
Default Battery mah question
I saw a post where someone purchased a Lipo that was marked 3S 1500mah, and they had it fail and disassembled it to learn it was actually only 1300mah. Well, I got two batteries from the same store, how do I tell what mah mine are?:?
Pappy is offline   Reply With Quote
Old 07-09-2009, 10:18 AM   #2
What type of charger do you have? Some will tell you the input value...
JeremyH is offline   Reply With Quote
Old 07-09-2009, 10:58 AM   #3
ya, run it down to the low voltage, plug it in and see how many mah's it takes. If your running lipo, you prolly have a decent charger.
slimeball is offline   Reply With Quote
Old 07-09-2009, 11:56 AM   #4
I use a Hyperion 6060i I believe it is.....I have to select a mah setting prior to charging.:? I was setting at 1500 up until I read that post, and then tried 1300 to see what happened. It went to 1299 and ended. So it may just partially charged.
Is there a way to tell by charge rate or something?
Old 07-09-2009, 12:21 PM   #5
Run it down and then set your charger to 1500mah @1.5amps. Then charge it and see what it comes up with.
Which batteries are you referring to? I have two 1500mah CKRC 3S lipos. One holds about 1390mah and the other 1480mah. You kind of get what you pay for with cheap batteries unfortunately.
MtnBkr is offline   Reply With Quote
Old 07-09-2009, 01:40 PM   #6
Do you have a volt meter? check the individual cell voltage; I would imagine that if the bats are not fully charging the voltage would not be reaching 4.2v/cell on a 1300mAh charge.
Ktbone is offline   Reply With Quote
Old 07-09-2009, 10:18 PM   #7
Yep, same batteries here.....They are working great for me, just there was a guy that had one fail and claimed that he disassembled the failed pack to find it was only 1300 or 1350 mah. Just got me wondering, and fearing overcharging mine.
