07-11-2009, 12:58 PM | #1 |
Newbie Join Date: Jul 2007 Location: Versailles
| Newbie servo upgrade question
I just replaced my stock AX-10 servo w/ a servo from Crawford Performance Engineering (200+ oz. torque for 20.99), but my question is this...when I turn on my crawler, the steering turns almost all the way to the right. Then when I turn my radio on, the steering centers itself, which I'm assuming is because of me adjusting my steering trim on my stock radio. Does it sound right for the steering to turn like that at start up, or is there some sort of adjustment i should've done when I installed it?
07-11-2009, 01:44 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Did you try(?): -Turn everything off. -Unscrew the horn from the servo. -Turn on radio. -Turn on servo/rig. -Center your Steering trim on your radio. -Reinstall servo horn making sure the tires are as straight as you can get them. You may have to adjust Steering trim a bit. |
07-11-2009, 01:46 PM | #3 |
Pebble Pounder Join Date: Feb 2006 Location: Evanston
Remove the steering horn from servo.Turn on radio.make shure the steering trim is set in the center of the adjustment on the radio.position wheels strait.install horn on servo.Ur golden |
07-11-2009, 02:09 PM | #4 | |
Rock Crawler Join Date: Feb 2008 Location: UK
Get into the habit of turning the Tx on first - if you don't, one day you will have an accident. | |
07-12-2009, 08:30 AM | #5 |
Thanks for the tips guys--it makes alot more sense to install/tune it the way you all described! I also appreciate the heads up on turning the tx on first; that seems like a valuable bit of info all newbies should know.
07-12-2009, 08:42 AM | #6 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
Yup first rule of RC: The transmitter is the first thing on and the last thing off. Not a big deal with cars and trucks but try forgetting with a 600 size heli you'll only do that once (if you're lucky) |
07-12-2009, 01:12 PM | #7 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
| I always forget this part you would think after replacing so many dead brand new AAs I would try a little harder to remember
07-12-2009, 02:10 PM | #8 |
Nothing worse than getting to the field and discovering your Tx is dead because you forgot to turn the damn thing off; thank god I've never done that This is why I convert all my tx to lipo with deans connectors; I can then just use one of the 3s lipos I have with me. |
