Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Noob Question
Old 11-08-2005, 03:29 PM   #1
Default Noob Question
Is it better the have a higher voltage or a higer mAh? Im lookin for a new battery for my frog. Dont Laugh
-Don
350jeepcj5 is offline   Reply With Quote
Old 11-08-2005, 04:26 PM   #2
TCS/Holmes Hobbies
SVEN's Avatar
mah is the capacity of the battery, so the more you have, the longer your run times will be. The mah of the most common battery packs range from 1500 - 3800 (There are exceptions).
Higher voltage = more power to your electronics. 6 cell battery packs are the most common type of battery used. 6 cells equals a total of 7.2 volts @ 1.2 volts per cell. Most, not all, esc's are rated for 4-7 cells, so that is 4.8 - 8.4 volts.
I don't know if a 7 cell pack will fit in your frog, but a 6 cell pack should (because that is what most vehicles are made for).
I would suggest using a 6 cell 3300mah Nimh stick pack. It will provide plenty of power and runtime. Or if you are a little ambitious go for the 3800 mah.
SVEN is offline   Reply With Quote
Old 11-08-2005, 04:32 PM   #3
k, thanks. i shouldnt have anyproblems with frying anything will I?
Old 11-08-2005, 04:39 PM   #4
TCS/Holmes Hobbies
SVEN's Avatar
What electronics do you have? If you use an MSC, buy an ESC as soon as possible. The Tamiya kits that I have bought came with an MSC, so I am just checking.
Old 11-08-2005, 05:03 PM   #5
i will have an esc, it is jr-racing sc-1 esc with 15turn motor limit, and the stock motor.
Old 11-08-2005, 09:11 PM   #6
TCS/Holmes Hobbies
SVEN's Avatar
Sounds like you are good to go then.
