Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: losi trans
Old 11-08-2005, 08:59 PM   #1
Default losi trans
Which losi trans are they putting in the tlt and what do you have to do to make it work?
whalebone is online now   Reply With Quote
Old 11-09-2005, 10:36 PM   #2
Makin "Bank" in ND!!
racerx's Avatar
I'm using a xxx buggy trans, you just lock up the ball diff w/ J.B. weld or you can drill through both outdrives ( the disc shaped part) and put some type of pin through the whole diff gear assy. then I used traxxas Jato axles cut the threaded end off where the smooth part starts put the drive pin in the axle w/ a little C.A. to hold it then push the metal end of the shaft into the outdrive cup with hot glue( do this part fast) then when id hardens trim of any that squished out and your golden!
racerx is offline   Reply With Quote
Old 11-10-2005, 12:15 AM   #3
is it as strong as the pede trans?I have a tlt my buddy made longer but i would like to make a tuber out of it looking for the best trans for the job lol
Old 11-10-2005, 01:26 AM   #4
Scale'n
k9popo's Avatar
The pede tranny is going to be your easiest more reliable bet as far as throwing it in and go...The losi and ae advantage is size and weight...Go with pede alot less work...Unless your into that??
k9popo is offline   Reply With Quote
Old 11-10-2005, 09:24 AM   #5
racerx's Avatar
K9 is right the pede is easier to swap cuz the drive shafts for the pede fit right on (duh!) and the axle end is easy to mod. Most people will recommend the steel u-joints fort the pede shaft others say not needed. Both require a little thought on how to install them, I've seen others stand the pede upright and still use stock chassis plates. If you plane on the tuber than you can lay it down so the motor is as close to the bottom as it can be and that will lower your center of gravity aka(cg) the lower the better. Hope this helps you out. Try to read buildup threads of others and look at the ideas people use. It worked for me!
Old 11-10-2005, 02:58 PM   #6
I know i spend two or three hour anight looking at everything i can find to do with the tlts thank you for the info the one i have now is getting the crap beat out of it and it needs a face lift the stock tranys doing fine with the 27t but the 55t on the way
