07-18-2009, 05:22 PM | #1 |
Newbie Join Date: Mar 2009 Location: Brisbane
| no.1 best upgrade
hey, for an axial rtr, what is the single best upgrade you can do? i was thinking of ckrc stage 2 but i saw some people bagging it. is it good? what else? |
07-18-2009, 05:40 PM | #2 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
Mayhem Ultimate Comp Wheels or a Tekin FX-R.
07-18-2009, 07:17 PM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Tires!!!!!!!!!!! then get the batt down off the roof, get a 10-12 tooth pinion and learn to drive it |
07-18-2009, 07:43 PM | #4 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
old hippy is on the right path. tires is easily 80% of your setup. if the tires dont hook up you'll never crawl anything. theres lots of things you can do without spending much $$ on the axial trucks. trim the skidplate and move the lower links inside the chassis plates. also, do the steering mod to the knuckles to gain extra turning radius. some bents links in the rear is a cheap hop up that really helps out. check out http://www.rccrawler.com/axialcompbuild.html for some other stuff to make the truck more comp worthy.
07-18-2009, 08:41 PM | #5 |
Newbie Join Date: Sep 2008 Location: Dallas, Texas
07-18-2009, 10:26 PM | #6 | |
| Wheels you can live without for a while. It took me a good 4 months to spin the hexes on mine. Even then if you can't afford Mayhems, a used set of Berg rims will do ya fine. The ESC is another very good step. Crawling is all about control. The stock ESC doesn't offer much of that... Quote:
Tires are a huge deal. Its the first basic mod for anything with wheels. Do spend ALOT of time driving it. Getting to know your rig is the best thing you can do, period. A seasoned driver with an off-the-shelf crawler will beat a noob that never runs his fully upgraded, multi-thousand dollar shelf-queen rig all the time. | |
07-19-2009, 03:27 PM | #7 |
I'll throw my 2 cents in. I don't think the stock tires are that bad. I may be the only person ever to think that...... Soften the foams up, add some weight to the wheels and run them. IMO, the biggest thing is to lower the center of gravity. As mentioned previously, get the battery off the top. Saddle pack NiMh's, or a lipo, either mounted on the front axle. Then internally shorten the shocks so they are about 4 1/8" long fully extended. Then drive the crap out of it. |
07-19-2009, 03:50 PM | #8 | |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
I would spend my money on a high torque servo (atleast 200 0z.) and some Losi comp claw tires. If your running the 27t motor then gear down to around a 12t pinion. | |
07-19-2009, 04:06 PM | #9 |
Rock Crawler Join Date: Oct 2008 Location: Florida
A quality esc., TEKIN, MAMBA, SIDEWINDER or ROOSTER. The Tekin has the best drag break IMO.
07-19-2009, 04:26 PM | #10 |
RCC Addict Join Date: May 2006 Location: nor-cal
tires and moving the battery both can be done for pretty reasonible |
07-20-2009, 10:47 AM | #11 |
Pebble Pounder Join Date: Dec 2008 Location: Pittsboro, NC
JRRacing high torque servo (9100T) and HotBody Rover tires..........that should keep you happy for a while.
07-20-2009, 12:38 PM | #12 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
some of the best mods you can do don't cost anything but time and a little work. move the batteries to the axle, inboard the links at the chassis, add weight in your tires. Then I would start with a Tekin FXR escmotor combo and some new tires, then upgrade the steering servo and steering linkage. Then I would 4 link the front and rear and replace the lower links with delrin ones. You do all that and you will have a very capable rig. Once oyu outgrow this setup its time to start shopping for a new chassis and a Dig and 3 ch. radio. |
07-20-2009, 01:00 PM | #13 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
lower your CG any way possible HB rover tires, stronger servo and double triangulation |
