07-20-2009, 12:00 AM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: Missoula
| Comp rules
I am curious about this: 2.1.2.1 – Super & 2.2 Class body must be 3” minimum height on sides. No less than 12.5” total length and full original width, and no less than 5” in the center. All bodies should resemble its original form (Jeep bodies look like a Jeep) What are they refering to 3" minimum height on sides and no less that 5" in the center? Is that 3" min from ground to bottom of the body, or the body itself must be 3" tall from bottom to roof? Same with the 5" center from ground to bottom of body or bottom of body to roof in the center? I was looking at the Pro-Line 83 Ram Charger body, looks pretty sweet. I like the scale look to it with the roll bar and spare tire mount. Here's a link. http://www.prolineracing.com/p-677-1...roll-cage.aspx |
07-20-2009, 12:17 AM | #2 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
07-20-2009, 12:27 AM | #3 |
I think I misread that the 3" is height from bottom to roof, but the 5" in center is the width. You can't modify the width must be original width, but at least 5" wide in center. At first I thought it meant 5" tall in center which didn't make sense cause then if it were 3" on sides and 5" center it would be triangular shaped, which is retarded. I must have had a brain fart...lol, thanks.
07-20-2009, 11:02 AM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: Pittsboro, NC
Sounds like you"ve got it now, but remember the rules also state that it must resemble the original form. So don't chop it up too much. |
