Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Gear Ratio?
Old 07-21-2009, 12:41 AM   #1
Default Gear Ratio?
just bought a ax10 scorp puting it all together and wondering what size pinon and spur gear i should go with not really looking to go fast but want supreme crawln abiltys
Crawln1221 is offline   Reply With Quote
Old 07-21-2009, 05:45 AM   #2
It will depend on the motor/batt combo. Most guys start around the stock 14/87 set up. I'm running 9/92 with a 500puller on 3s.
oldhippie is offline   Reply With Quote
Old 07-21-2009, 07:06 AM   #3
On the lookout for Rocks
constantmotion's Avatar
The stock setup works great.
constantmotion is offline   Reply With Quote
Old 07-21-2009, 08:35 AM   #4
im going with the novak rooster esc nd 50t motor not sure on a battery yet does a battery really make all the differnce? i was thinking about a 14t pinion and a 93t spur? but yet im not sure at all what works better first crawler here
Last edited by Crawln1221; 07-21-2009 at 08:45 AM. Reason: typed the same sentence twice
Old 07-21-2009, 07:21 PM   #5
Their is a big difference between running a big Sub-C 7.2V stick pack VS a 11.1V Lipo. Less weight and much more power and speed.
14/93 should work fine. Stock is 14/87 so you are not far off. If anything your gearing will give more TQ so the motor should have less work if you run a taller tire like the Rover's.
TLTRyan is offline   Reply With Quote
