07-21-2009, 03:13 PM | #1 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
| First time lipo n00b HELP!!!
Just got my lipos and charger today, and i was wondering what i should charge them on for the first charge. They are 1500mah 3s 20c lipos. On the charger i can set it to lipo charge/lipo balance/lipo fast charge and i think thats it. Does it charge and ballance on lipo ballance? How many amps should i charge them at? Any info you have for me is appreciated. |
07-21-2009, 03:19 PM | #2 |
Its also go a lipo storage setting and a lipo discharge setting. When is it nessessary to discharge the lipo? I also put the cutoff at 1500mah because thats how big the batteries are. Is there anything else i should change? Which setting should i charge it at and how many amps?
07-21-2009, 03:20 PM | #3 |
Rock Crawler Join Date: Feb 2008 Location: UK
Yes, it'll charge and balance on the balance option - at least, every charger that I've seen will. Post a link to the charger so that we can be sure. A 1500mAH pack should be charged at 1.5A. Some people recommend doing the first charge at a lower rate, but I've never bothered. |
07-21-2009, 03:26 PM | #4 | |
If you are going to leave them in storage for a long time, discharge them down to 3.8v per cell - that's probably what the "storage" setting will do. No idea what the "discharge" option is for - you should never run a LiPo down below about 3.2v per cell. Chances are it'll never work again. Is it possible that the "discharge" option is for use with NiMH packs? | |
07-21-2009, 03:27 PM | #5 |
Its the iMAX B6, the one you told me about in my other thread. Should i do a balance charge for the first one?
07-21-2009, 03:37 PM | #6 | |
It also seems to do a more thorough check of the pack if you do a balance charge - makes sure that you've selected the correct type and number of cells. Prevents you setting the charger up incorrectly. The manual that came with my charger wasn't very good. When you do a balance charge, it's best to connect the balance plug and the main power leads. Not strictly necessary with a 1500mAH pack, but the balance plug can only handle a couple of amps. When you get bigger packs, you'll need to use both sets of leads, so it's a good idea to get into the habit right from the start | |
07-21-2009, 03:38 PM | #7 |
Quarry Creeper Join Date: Jul 2008 Location: Back in Sunny SoCal
| Not an expert, but I think Yes. might as well balance it. I balance charge my lipos every charge....... don't think it hurts it. and doesn't take much longer.
07-21-2009, 03:53 PM | #8 |
Alright thanks guys, i just put them on 0.5A balance charge, we'll see how it goes.
07-21-2009, 05:31 PM | #9 |
07-21-2009, 05:55 PM | #10 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
where did you get your batteries and charger
07-21-2009, 05:56 PM | #11 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
Remember do not drain lipos! They should never be run down to 3.0v in fact I don't like mine to dip below 3.5v. The rule of thumb is 80%. You should be putting back in no more than 80% of the charge; so on a 1500mAh pack that would be 1200mAh plus a few mAh for heat inefficiency. If you have a lipo cut off make sure it's set to higher than 3.0v/cell.
07-21-2009, 06:20 PM | #12 | |
| http://www.ecpower.com.hk/index.php?...1523848de5f674 http://www.ecpower.com.hk/index.php?...roducts_id=186 I will DEFFINITELY be buying at least 2 more lipos from these guys. Took 7 days total to get here. (counting a sunday) Quote:
07-21-2009, 06:36 PM | #13 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
07-21-2009, 06:45 PM | #14 |
07-22-2009, 03:04 AM | #15 |
cool probably going to get this charger and lipos
07-22-2009, 03:08 AM | #16 |
how much run time are you getting with these
07-22-2009, 06:32 AM | #17 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
That EC lipo is exactly like the pack I have that has the CKRC sticker on it. The backs look identical. I got it used so maybe someone just put the CKRC sticker on it, but you may want to check that it is actually 1500. The ones from CKRC were only 1300 according to another thread. I have a Venom charger so there is no setting for mah on mine so I probably can't burn it up. |
07-22-2009, 09:47 AM | #18 | |
Just because it doesn't have a "setting" doesn't mean it can't hurt the battery. For all you know it could be outputting 3A, and that could definately cause issues for a small pack. I bet if you turn that charger over and look at the back where it should list the input/output ratings it will say what its output is. If not, you should make an effort to find out, its in yours and your lipo's best interest. I would suggest to anyone getting into lipos or wanting to charge lipos to get at the minimum a charger with a few charge rate ranges. Even the simple $20 electify lipo chargers have 100mah - 1000mah selectable, they are a very safe charger as well. Not as nice as a good balance charger with display, but will at least do the job. | |
07-22-2009, 10:40 AM | #19 | |
| I highly recommend them, fast shipping, and so far everything is working perfectly. Just finished the first pack, lasted 40-50 minutes. Quote:
07-22-2009, 01:41 PM | #20 | |
It can only charge 2 and 3 cell Lipos so I wouldn't think it would be putting out 3A! Once again...don't think it will hurt the battery. | |
