07-25-2009, 04:03 PM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: Grants Pass, OR
| CC01 electronic problems
So I bought a CC01 pajero kit a few weeks ago and have been buying my parts slowly. I have all my electronic parts now but I still have a few questions. This is what I have: stock Tamiya motor, Tamiya TEU-101BK esc, Traxxas TQ2 controller, Traxxas 2215 receiver, Traxxas 2070 digital servo, and a Pirahna 2000 7.2volt battery pack. My problem is the battery lead from the esc does not fit into the receiver. Different number of pins and thicker. Do all I need is a different connector or do I have a wrong part? Also does anyone have a list of plug and play electronics for the CC01?
07-25-2009, 04:32 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
Can you post a pic of the lead? Looking at a pic I found online it should plug right into the Traxxas receiver. |
07-25-2009, 04:36 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
the esc lead just goes into the ch2 spot on the receiver not the 2 pin bat spot
07-25-2009, 05:47 PM | #4 |
Newbie Join Date: Jul 2009 Location: Valley Springs
If it is that your trying to put the wires into the battery port on the reciever, dont feel bad i just had that same problem yesterday with my copperhead kit but as i was told and want to pass on "1 for turn, 2 for burn" a little rule of thumb and some word association.
07-25-2009, 11:58 PM | #5 |
I have a lead from the esc plugged into chan 1, servo lead in chan 2, but there is another little two pronged lead also coming off the esc which I assumes plugs into the battery slot on the receiver to power it. I will post a pic when I get back to my pc.
07-26-2009, 04:44 AM | #6 |
Rock Crawler Join Date: Feb 2008 Location: UK
I googled that ESC, and it's a very strange design. It has the normal receiver connector, a power switch and a third wire that goes to the Bat port on the receiver - no idea why Tamiya chose to send the BEC output on a separate wire. A further google showed this:http://www.goldstarstockists.com/downloads/teu101bk.pdf Seems that the extra plug doesn't fit in some receivers - you need an adaptor or the power switch that matches the Rx. No idea why it fits some receivers and not others - I thought these connections were standard? |
07-26-2009, 09:23 AM | #7 |
in that case i would just shave it till it fits. haha
07-26-2009, 09:27 AM | #8 |
You have to plug the 2 wire lead into your receiver. This esc draws power from the receiver. As stated on towers site "Must be used with a receiver that has BEC" Plug the 2 wire lead into the battery slot on the receiver. You may have to trim the plug a bit. I know when using some servos on JR and Spektrum receivers I sometimes have to trim the plugs to fit. |
07-26-2009, 09:57 AM | #9 | |
07-26-2009, 10:43 AM | #10 |
i never pluged mine in and it worked just fine
07-26-2009, 03:06 PM | #11 |
Ended up shaving the connector to make it fit. Then since it was a two prong going into a r prong, I plugged it into the outside two. Works like a charm. Thanks for all the help guys!
07-27-2009, 05:27 AM | #12 |
07-27-2009, 11:56 AM | #13 |
Yep, the red one was the one in question.
08-02-2009, 10:30 AM | #14 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
| I have this reciever in my CC-01, and I used a Futaba controller, but it should be the same hopefully. What I did was plug the red lead into the battery connection on the first two prongs. Those are the positive negitite poles on a reciever. I did it just as a precation if that ESC did the BEC a different way or something. The black connector goes in the channel spot. If the battery connector doesnt fit, just shave the plastic so it fits. Mine was tight.
