| | #1 |
| Newbie Join Date: Jul 2009 Location: Pacifica
| Why does it seem that no one runs turnbuckle upper links? I would think the adjustability would be beneficial. Or do crawler suspensions just not need to be as dialed in as an onroad or offroad racer? |
| Sponsored Links | |
| | #2 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| Most of your adjustments are moving the uppers up and down to adjust squat/anitsquat. Making the link shorter or long only affect your pinion angle. |
| | #3 |
| OK, that makes sense, but now you just raised another question, LOL I have a TCS Edge chassis I am building. The upper link mounts are three holes lined up parralel to ground. No up and down adjustment. I guess I would have to drill new holes to adjust squat or antisquat. I figured with adjustable uppers, changing length would change upper and lower link intersection points (obviously not as much as an up and down change at the chassis). |
| | #4 | |
| Day By Day ![]() Join Date: Nov 2006 Location: spring hill TN
That would only be true if you were adjusting them the same.If you adjusted one more than the other you would be tunning preload.Preload could be used to shift weight from one tire to another to help get even traction and could help fight torque twist.But I agree it would not change squat #'s | |
| | #5 |
| Thats how we preload drag cars and also fine tune pinion angles. I guess I am used to minute changes making big differences on 1:1 scale, LOL |
| | #6 |
| Dave's not here!!! ![]() Join Date: Jul 2005 Location: Silverdale, WA
| It wouldn't be that hard, a turnbuckle for Slash would work, might have to cut it down a little. Throw it on there, test it out then post a thread on it, that way we all learn something! |
| | #7 | |
| | #8 |
| Rock Crawler Join Date: Sep 2008 Location: Portland
| I have done this, I didn't really find it beneficial. All it does is improve your pinion angle and screw up your steering, you end up essentially steering down, your tires roll really bad as well. |
| | #9 |
| And looks like they are 6-32 turnbuckles. #31 drill is .120". An 8-32 requires #29 drill and 6-32 uses #36. |
| | #10 |
| Rock Crawler Join Date: Jul 2008 Location: Port Angeles
| I use turnbuckles on a few of mine, both for upper links, and steering tie rods. Mostly revo parts since they're pretty beefy. Main reason I do do it though is my fabrication skills are somewhat lacking |
| Thread Tools | |
| Display Modes | |
