| | #1 |
| Newbie Join Date: Jul 2009 Location: just outside of nowhere
| Ok just thought I'd throw this out there to see what everybody thinks. What is better a cva axle or a universal joint type axle? Personally I think a universal would handle a little more abuse than a cva, also it seems like you could push your steering just a little further with a universal. |
| Sponsored Links | |
| | #2 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| Yeah, the universal joint would probably withstand more abuse than the pin in a CVD....but the u-joint would have to be pretty small or the axle would have to be pretty large. Also, if you brok one, there'd be no replacing the joint. |
| | #3 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| Well if you look at the rest of RC as proof you'd have to side with the CVA/CVD. The Universal system in RC is very old...way back when it was the common upgrade. The problem became strength of the small pieces....MIP then created the CVD/CVA which revolutonized everything and is now the true de-factor standard (except Kyosho). |
| | #4 |
| Pebble Pounder Join Date: May 2009 Location: Killeen TX
| the universal is the best way to go i run traxxas shafts in comps with a bunch of guys running cva's and they are always breaking them. while i fall of large drops over and over and never break anything. go traxxas. |
| Thread Tools | |
| Display Modes | |
