Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Running digs on MOA set up
Old 07-30-2009, 12:31 PM   #1
Got Worms?
losikid's Avatar
Question Running digs on MOA set up
HI, i plan on doing a MOA on the LCC but i'm not sure how to set it up electronics wise, i would like to keep the tekin fxr that i have on it now if i could, Also how do you setup a dig without the transmission.
losikid is online now   Reply With Quote
Old 07-30-2009, 12:53 PM   #2
Choppin' it up.
Szczerba's Avatar
I use the Tekin Fx-R on all 3 of my rigs, super with elec dig, 2.2 berg with elec dig and my semi-scaler with the tekin fx-r. Love em.
Dig Diagram (middle of page) I used on my berg. Same for a one esc, two motor setup, so it should work on your Losi MOA.
Dig wires ?
My berg build. Sort of shows you the wiring setup. There are probably better pictures out there.
Shane's Kamikaze Kustoms Zero ST Berg
Just keep searching and reading. It took me a few days to get it straight in my head. It’s not hard to make one and costs about $20 and a good soldering iron, Two Holmes Hobbies switches and an HS-55 Hitec servo. You’ll need a 3 channel radio though (you might know that).
Hope that gets you started.
Szczerba is online now   Reply With Quote
Old 07-30-2009, 01:04 PM   #3
Shut up Dave
jetboat's Avatar
switches are cheap and relatively easy... PunkRC.com dig unit is the cleanest/easiest way to go though and it has an indicator light to tell you which/if the dig is engaged.
I have ran both and only recommend the punk over switches because it is cleaner and easier to install (not that either is hard)
jetboat is online now   Reply With Quote
Old 07-30-2009, 01:08 PM   #4
Choppin' it up.
Szczerba's Avatar
Good call, forgot about the Punk Switch.
Old 07-30-2009, 01:08 PM   #5
Make a dig with switches and micro servo
Or get the punk rc dig switch...This is what I use and it works great and alot easier and cleaner wiring. http://www.punkrc.com/index.php?main...6e20dc8cfd2206
sddill is offline   Reply With Quote
Old 07-30-2009, 01:15 PM   #6
Got Worms?
losikid's Avatar
where does the servo go, in between the switches, also where could i get those switches
Old 07-30-2009, 01:20 PM   #7
I ran a berg with the switch set up and then the punk rc set up.... it was much nicer with the punk unit, everything seems much smoother going that route, and like was said everything is routed cleaner.
megacabcummins is offline   Reply With Quote
Old 07-30-2009, 01:23 PM   #8
Choppin' it up.
Szczerba's Avatar
http://holmeshobbies.com/product.php...&cat=12&page=1
Yep, look at my berg link I put in the above post. glued the switches onto the servo.
The punk R/C unit may be less hassle but it will be triple the cost. But you spend the time to make the mechanical switch too! either or.
Old 07-30-2009, 01:32 PM   #9
Or get another fxr and a good radio
oldhippie is offline   Reply With Quote
Old 07-30-2009, 03:35 PM   #10
TN State Champ 2011
Pdog7's Avatar
You can also use micro switches from radio shack instead of the Holmes Hobbies. Holmes are definitely better but, easier to get from radio shack.
Pdog7 is offline   Reply With Quote
Old 07-30-2009, 03:39 PM   #11
Got Worms?
losikid's Avatar
that punk switch is more like 10 times the cost, 6 dollars for switches, 60 dollars for a punk switch
Old 07-30-2009, 06:07 PM   #12
plus $30 for a good servo.
get the punk switch, you wont regret it!
jamesdicken is offline   Reply With Quote
Old 07-30-2009, 06:16 PM   #13
Gold Star Baby!
Colby's Avatar
Cant forget when/if those switches or servos go bad. It always seems to be THE DAY BEFORE THE COMP TOO!!!
Colby is online now   Reply With Quote
Old 07-31-2009, 12:31 PM   #14
Got Worms?
losikid's Avatar
already have a servo for the dig on my car now, how easy is it to convert from a switch right now then go with punk switch, kinda on a tight budget
Old 07-31-2009, 12:35 PM   #15
I'm Dracula, Bitch.
JeremyH's Avatar
LK, here's a good write-up on the DUD dig (that uses switches):
D.U.D. Rear Dig "Write up"
Jarod only used one switch to dig the rear motor, but you can add another and have a dig on the front motor as well.
JeremyH is online now   Reply With Quote
Old 07-31-2009, 02:15 PM   #16
Got Worms?
losikid's Avatar
thanks
