Can I use Lipo's with any ESC? I have like 20 Novaks. Mostly Dually's, Explorer's, 410-m5's, & Duster Sports. Can I use Lipo's with any of these ESC's? Or do I have to buy a Lipo capable ESC? Thanks, -Vince |
Any ESC that works with a 6-cell NiMH or NiCad pack will work with a 2s LiPo. The nominal voltage is very slightly higher, but not enough to cause damage. In fact, a top quality NiMH will generally give more voltage than a 2s LiPo. The problem with using LiPos is that they really hate being run flat. By the time you notice the fall-off in power, it's often too late - the pack is damaged. this is especially true in a crawler, where you rarely pull a high current from the pack. Modern ESCs have a LiPo cutoff so the pack never runs too low. |
I use this from helidirect on my losi mrc. It works great and will keep you from runnning your lipo too low. Plus, it's really cheap. http://www.helidirect.com/iosc/produ...oducts_id=8158 |
So do you recommend just sticking with nimh batteries. Unless I upgrade to a modern ESC? Capable of cutting the lipo off at a certain point. |
I would, safer |
a $25 dollar volt cutoff is all you need. Works will all Novaks, well, its made by Novak. Don't know why it doesn't work with the XL-5.... http://www3.towerhobbies.com/cgi-bin...?&I=LXPGM8&P=7 It has both the visual blinker, and a throttle disruption so you can tell when you drive. Quite nifty! :) |
Thanks for all the replies. So you're telling me I can run my Novak Dually with a 3s Lipo & a $25 cutoff switch & i'll be safe? |
The Novak Dually is only rated up to 7 cells, which is 8.4v nominal. A 3s LiPo is rated at 10.1v nominal, so it's likely to cause damage. Stick with a 2s LiPo and you'll be fine. |
Lipos catch fire, and you can't put them out, But ni-mh's and ni-cds explode. :shock: pick your weapon.:ror: |
Narly1 |
I put it down to old age! |
Oh wow! OK, so I can use my 410-m5's with a 3s. Cool perfect. My next question is. Will that 11.1v 3s lipo make the truck considerably faster? |
Thanks again for all the replies too. They're really helping me out. -Vince |
hell yes just dont burnout the motor which are you using |
Its all going in this... I plan to widen the stance using the Tamiya Blazing Star Control Arms & Axles "thumbsup" http://i187.photobucket.com/albums/x...evys10dime.jpg |
