| | #1 |
| Newbie Join Date: Mar 2009 Location: Brisbane
| hey, i am wantng to buy the ckrc stage 2 kit for ax10 however i have an ax10 rtr. what will i need to purchase aswell to make it completely compatible with the rtr? thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Oct 2008 Location: Florida
| I use these for lower links http://www3.towerhobbies.com/cgi-bin...&I=LXHFV9&P=OW uppers http://www3.towerhobbies.com/cgi-bin...&I=LXSGU4&P=OW then tcs 4 link it http://www.tcscrawlers.com/On-Sale-5...g-p-16612.html and http://www.tcscrawlers.com/On-Sale-3...g-p-16613.html shocks http://www.tcscrawlers.com/Team-Losi...2-p-16932.html battery http://www.tcscrawlers.com/TCS-Crawl...r-p-16619.html and http://www.tcscrawlers.com/TCS-Delri...h-p-17203.html You can mod or make a new skid or buy one of these http://www.tcscrawlers.com/TCS-Crawl...n-p-16695.html These are all good competitive upgrades. The reason I like the upper and lower links above, one the revo ends are tough as nails and they are included, two IMO the steel slides over rock better, three you can use the turnbuckles on the uppers to give you minor adjustments as well as they are thinner wich gives a little more clearance for Shock placement. You can also bend the revo lowers if you want bent links. Good luck once you dial it in and find what works for you the ax10 is a great foundation. One last thing dont waist you money on expensive rims just weight up the front and trow on some HPI Rovers. |
| | #3 |
| are the lower links long enough, and is everything just drop in for the rtr? thankyou for the post tho. thanks, Cal Last edited by caljones; 08-06-2009 at 01:23 AM. |
| | #4 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| AX10 Kit, AX10 RTR, AX10 ARTR, and the AX10 RTC all use the exact same parts and are direct replacements of each other. |
| | #5 |
| I wanna be Dave Join Date: Jun 2005 Location: With my family
| I would recommend contacting R2J on here. He can set you up with all the links you need out of Delrin. < Best stuff IMO. |
| | #6 |
| constantmotion, i ment that because the rtr comes with one piece links, steeringlinkages etc, do i need to buy the rtr hardware upgrade kit? sorry aout the confusion |
| | #7 |
| RCC Addict ![]() Join Date: Apr 2008 Location: Sacramento
| One thing to remember when you get your new links it to make sure they are the same size as what you have now from eye to eye, unless you plan on changing your mounting locations, or it will through off your wheel base and pinion angles. |
| Thread Tools | |
| Display Modes | |
