Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Question on axles
Old 08-04-2009, 02:07 PM   #1
Default Question on axles
Looking at getting a set of Berg axles. I keep reading about clocked axles. What do you mean by clocking a axle. Also the term lockouts on a rear axle. I have seen that I you should go with an aftermarket lockout.
Thanks,
Neil
nsg1rc is offline   Reply With Quote
Old 08-04-2009, 02:17 PM   #2
I'm Dracula, Bitch.
JeremyH's Avatar
Clocking = Rotating the center diff upward
Lockout = fixing the steering knuckles so that they dont move
JeremyH is online now   Reply With Quote
Old 08-04-2009, 03:00 PM   #3
Then there would be no real purpose to clock a MOA crawler. Would that be correct? I can understand clocking with a trans, to change the driveshaft angle
Old 08-04-2009, 03:30 PM   #4
You clock Berg axles to get the motor up and out of the way, to keep it from contacting obstacles.
Robb is offline   Reply With Quote
Old 08-04-2009, 08:12 PM   #5
I'm Dracula, Bitch.
JeremyH's Avatar
Yep, like Robb said....it's purley for clearance on MOA. For shafties, it can help with driveline angles...
