Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: winch cable/rope, and roller thingo. ?
Old 08-04-2009, 07:19 PM   #1
Default winch cable/rope, and roller thingo. ?
first off hi to everyone. i dont really consider myself a complete newb
but i didnt want to clog up the 1.9 section with all its cool builds in
there. anyway i have a 1.9 jeep that i made a servo winch for (from info
i got off here) anyhoo i got her working and it runs great, but all i had lying around was heavy fishing line. it functions well and is strong i just want the scale look. what rope or line should i use? my other question
is the roller thingo that lets the cable go at an angle without chaffing.
are these homemade or do you buy them? thanks in adance.
heres my jeep :Click the image to open in full size.
heres a pic under the hood showing my servo winch.
the winch hub is a sewing machine cotton bobbin.
thecrusader is offline   Reply With Quote
Old 08-04-2009, 09:19 PM   #2
On the lookout for Rocks
constantmotion's Avatar
Here's a link to some scale winch cable from TattooKenny
http://www.rccrawler.com/forum/showthread.php?t=184045
constantmotion is offline   Reply With Quote
Old 08-05-2009, 05:13 AM   #3
cool thanks. that stuff looks great but i might end up having
to use watever i can get my hands on.anyone have any ideas
for the rollers?
Old 08-05-2009, 05:22 AM   #4
tjb
Grab a 3Racing winch..
http://www.shop.rpphobby.com/product...&categoryId=61
Will solve all your questions, plus for the price if it takes a dump on you, you still have a working fairlead (the part you're looking for) and housing...
They are strong, and look great..quality control is a bit hit and miss though. But worth it either way
tjb is offline   Reply With Quote
Old 08-05-2009, 08:29 AM   #5
Fumb Ducker
DonsATV's Avatar
If you feel like fabing a roller fairlead check this out: Custom steel bumper + fairlead
Or you could get one of these non roller fairleads: http://www.freewebs.com/thescaleshop/fairleads.htm
DonsATV is offline   Reply With Quote
Old 08-05-2009, 09:18 AM   #6
There used to be a Vendor on here that sold the Delrin non roller fairleads.
Old 08-05-2009, 01:31 PM   #7
TEAM LERK DOIN WORK
JRock's Avatar
I used a Nitro pull start cord and it works great for the winch line I used a traxxas ball end to run the line through so that way it feeds the line right back in to the spool and when you winch to things the ball of the ball end moves any direction so the line feeds in and out perfect. Works great for a modded servo winch. Hope this helps
JRock is offline   Reply With Quote
Old 08-05-2009, 02:46 PM   #8
i used builders line ,looks like proper scaled down rope .. and just screwd two star shaped servo horns together with a spacer between them. works perfect.
Reaper09 is offline   Reply With Quote
Old 08-05-2009, 02:57 PM   #9
At Michael's craft store I found multiple kinds of nylon coated wire (in multiple strand counts, up to 26lbs test, up to 15' lengths) and synthetic cordage for pretty good prices (don't remember the pull strength on the cord, but looked like it would work well for scale synthetic winch line). They also had scrimps and wire guardians.
If you've the resources locally, you're probably set. If not, definitely see Kenny's thread.
JeepinCA is offline   Reply With Quote
Old 08-05-2009, 06:08 PM   #10
wow. thankyou thankyou thankyou. your guys are
more than helpful and i bought 2.5m off kenny.
i didnt respect such a reply. you guys are awsome
