how long is a comp run? How long does it normally take to run an average comp course for a Super? I am sure they vary by course design, but just in general, would it take 5 minutes, 15 minutes, or whatever? Just wondering if I need to upgrade batteries of if I can get by with the old mostly worn out cells I already have. |
Rarely is it over 10 minutes, though. |
We run three 5 minute timed courses. So 15 minutes total. |
Our courses vary from 3-7 minutes... |
Ours can be anywhere from 5-10 minutes. Like someelse said. You need to find out who is running the comp and find what they use. Most every major comp uses 4-5 minutes "thumbsup" |
xtra batteries and a charger on hand will also help. by keeping them topped off in between runs u can allways have that little xtra kick and not die on the last course a few feet from the finish. that and after the comp with xtra batteries you can allway splay after and learn some new tricks from your fellow drivers |
Thanks, looks like I need new batteries, I am getting maybe 5 minutes out the old 2000 Sanyos. |
did i hear sanyo those must be antiques 8) |
go here best batteries iv ran and very cheap http://ecpower.com.hk/index.php?main...637c14798e3cd5 |
and for a charger http://ecpower.com.hk/index.php?main...roducts_id=186 |
Will the EMaxx EVX work with a 11.1 Lipo? |
The EVX will work, but it doesn't have a low-voltage cutoff. |
Sanyo's?? sell em as collectors items! "thumbsup" |
