08-08-2009, 01:08 AM | #1 |
Newbie Join Date: Jul 2009 Location: Panama City
| big bore shocks
I'm looking @ getting a set of traxxas big bore shocks I have a stock ax10. Do I get the XL or the XXL??:? |
08-08-2009, 08:46 AM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| I would not get the XXL. If ya do the rod end mod the xl may be too long. I'm running the long big bores with rod end mod and they are alittle long on my KK zero 4.0. They give about 2.50" skid height on my stock ax10 chassis.
08-08-2009, 10:46 AM | #3 |
RCC Addict Join Date: Nov 2007 Location: BV
Slash/rustler/stampede rears and T/E maxx shocks are all 4" long. Slash/Rusty/Pede fronts are 3.5" long. Revo/jato shocks are 3.5" long I don't know of any other sizes other than 4tec shocks which are very short. The big bore XXL's are the same length as pro series XL's. For a stock axial chassis I'd advise 4" shocks. For the best deal get the T/E maxx set, I just picked up a set of 8 from stormer for about 63 bucks, with springs |
08-08-2009, 12:52 PM | #4 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
arent the bandit fronts only 3 inches
08-08-2009, 02:57 PM | #5 |
Rock Stacker Join Date: Jul 2009 Location: worley/boise as of aug 20
can you run the internal springs on them .and do the caps come off likt my stock ones do
08-08-2009, 03:20 PM | #6 |
| Sure can. That's the recommended set up for the RCP Hustler chassis for super class. You can in fact buy the shocks and internal springs at RCP Crawlers. They'll go together a bit different than stock Axial shocks,but they'll work fine. |
08-08-2009, 03:25 PM | #7 |
cool i just got the edge will that work to with them
08-08-2009, 03:29 PM | #8 |
08-08-2009, 03:30 PM | #9 |
cool thaks for the info |
08-08-2009, 07:05 PM | #10 |
thanks guys thats alot of info I ordered the big bore traxxas and the tcs internal shocks I'm going to run them sprung though not drooped |
08-08-2009, 07:49 PM | #11 |
Pebble Pounder Join Date: May 2009 Location: Cincinnati
i run big bores with cap mod on stock a 10 chassis,belly height is 2 7/8"Perfect IMO..Can move shocks and links around and get anywhere from 2 3/4" to 3" Cap mod is easy and works great no leaks,smooth as butter..Love these things,and the springs that come with work fine for me but my rig heavy!Buy the eight pack for the maxx and split with a buddy!Great shocks for thirty bucks!Cant beat it....
08-08-2009, 08:22 PM | #12 |
what cap mod? I noticed the shocks don't come with ball end in the caps |
08-08-2009, 09:12 PM | #13 |
| You basically just cut the mount off the cap, drill a hole, put a screw through it and put a bottom shock end on it with some RTV to seal it up. Gives you a ball end and a little extra length |
08-09-2009, 10:11 AM | #14 |
we used o rings rather than rtv to seal,with chamfered screws so not to tall to hit bladder...If running droop i suggest 1/4" fuel tubing spacer to not let shock totally bottom out.Have seen bladders damaged riding droop with shock bottomed out!
08-09-2009, 06:51 PM | #15 |
Thanks again, I plan on running internal shocks on top of the piston so it stays sprung Do I still use the top bladder on the top of the traxxas shocks or an O-ring to seal the cap? |
08-10-2009, 02:07 PM | #16 |
Pebble Pounder Join Date: Aug 2009 Location: ST. George
So did you go with the t/e maxx shocks?
08-10-2009, 09:31 PM | #17 |
08-11-2009, 06:50 AM | #18 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
you'll be running droop as well once you see just how well his truck works
08-11-2009, 07:38 AM | #19 |
Pebble Pounder Join Date: Aug 2008 Location: Cary, NC
08-11-2009, 09:02 AM | #20 |
