| | #1 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| Here ya go. RCCRAWLER tips, cheap tricks / parts guide. Last edited by BENDER; 03-01-2007 at 01:25 PM. |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Mar 2007 Location: hartwell
| I've been looking into building a crawler but I dont know where to start or what is the best choice for me. I want somthing strong but with a little speed. ..also money will be an issue....thanx for any help.. |
| | #3 |
| Newbie Join Date: Sep 2007 Location: benton
| very green to the rc world,need any infromation on what to do to give my highlift 350 more power,more battery life,more flex,stronger servos etc....as you can see,i know nothing about this sport.its pretty cool though,airbrushed body,2.2moabs,beadlock wheels,mainly dress up options |
| | #4 |
| Powered by Awesome ![]() Join Date: Sep 2004 Location: Castle Rock, Colorado
| visit the 1.9 scale section off of the main forum page.. or search f350 in the search box... theres LOADS of info on here! |
| | #5 |
| Newbie Join Date: Oct 2007 Location: wolcott
| just got a high lift and want to get the scale look out of it so where do i start? plus what material do you use for the frame rails? |
| | #6 |
| Newbie Join Date: Jan 2008 Location: canada b.c.
| wondering if anybody could help me with a small problem. i was wondering where the pos and neg posts are on my Integy Lathe Motor 55 Turn Single Wind there is like six spots that look rite but im not sure. Last edited by RCRichard; 01-06-2008 at 05:15 PM. Reason: left some info out |
| | #7 |
| Pebble Pounder Join Date: Jan 2008 Location: foothills of va.
| hello, im using the same motor, your positive &negative should be stamped on the endbell side where you solder wires on. youll see a plus symbol or minus symbol. &solder accordingly. hope this helps. |
| | #8 | |
| Newbie Join Date: Mar 2008 Location: mesa
| | #9 | |
| Rock Stacker Join Date: May 2008 Location: MIDDLE OF THE DESERT
If you can't find the + and - just solder them in place on a tab next to each brush braid. You can control the direction (f-r) by a swith on your controller. On a DC motor polarity doesn't mean much. | |
| | #10 |
| Newbie Join Date: Jul 2008 Location: Kissimmee
| Polarity means a TON if the motor uses any timing. If it is a zero degree motor, then it doesn't matter, since brush spring tension and brush compounds should be the same + to - . Not a pulling or crawling guru, by any means, but i've been around electric motors almost all my life. Note, if you find a + or a - symbol near either brush hood(the metal part the brushes and springs are on) then you can solder to any metal part of the hood with the correct wire and it will work. One entire side is positive and one entire side is negative, both are insulated from each other. ...Jim W.E.D. |
| | #11 |
| Newbie Join Date: Sep 2005 Location: SEBEWAING
| what is a good set of crawler tires |
| | #12 |
| Newbie Join Date: Mar 2009 Location: Frederick
| I bought a Axial Scorpion RTR to see if I would like the hobby, low and behold I can't stop. I've upgraded the tires to Pro-Line Flat Irons w/mem foam and the chassis has been up graded to the SWX. The chassis looks to narrow for a dig unit. Any sugggestions... |
| | #13 | |
| | #14 |
| Newbie Join Date: Mar 2009 Location: Northeast Pennsylvania
| Thank You for Compiling the Resources. |
| | #15 |
| thanks Bender for the 411. Much appreciated |
| | #16 |
| Once again i'm back for more! With so many different shocks on the market can you give me the low down on adjustable shocks for an axial with SWX chassis (awsome design by the way). Some say Losi and some say Traxx shocks. What should I be looking for when shopping shocks? |
| | #17 |
| Newbie Join Date: Feb 2009 Location: cape breton canada
| i thought i saw a thread about how to get pics of your truck on here, but for the life of me , i can't find it. please help. also how to get avatar pics? |
| | #18 |
| Newbie Join Date: Mar 2009 Location: Waynesboro
| i have a set of emberg shocks that i am putting on a wheely king DNA chasis i noticed that it was really stiff when i put the shocks on the chasis what would be a good weight of oil to put in them to soften them up |
| | #19 |
| Newbie Join Date: Mar 2009 Location: New Brunswick, can
| im not to sure but i think there should be a little a very little + - next to the biggest post on there. hope that helps!! |
| | #20 |
| Newbie Join Date: Mar 2009 Location: Bothell
| That was extremely helpful. Thank you. Noob here from WA! |
| Thread Tools | |
| Display Modes | |
