08-13-2009, 09:42 PM | #1 |
Newbie Join Date: Aug 2009 Location: Snowmass Village
| tire foams?
im wondering the diffrent ways i can cut my foams for for scorpions? any suggestion would be great!
08-13-2009, 09:50 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
i sugest not cuttin them... what tires are you runnin the hammer or lizzards? if the lizzards get new tires.. if hammers tray adding a bit of weight to the wheels
08-13-2009, 09:51 PM | #3 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
You can do a star cut or channeling but you really don't need to. I would recommend using the foams the way they are unless you are going to double stuff. The big question is what kind of tires.
08-14-2009, 09:44 AM | #4 |
Newbie Join Date: Aug 2009 Location: Ontario
depending on if you are planning on buying new tires or not, hers another option: i ordered imex claw dawgs from tower hobbies for my ax-10, however they have only a 4" outer diameter(dispite what the tower hobbies website says) they came with a 4" memory foam type foam, which i narrowed and used inside the lizards, which perform ok for general use in my opinion. so, if you order new tires, order them without any foams, and order a separate set of foam inserts for regular 2.2" tires, it till give a 5" tire a little over 1/2" squat, the bigger tires may need bigger foams. i find this method works well. heres a pic to make it a little more clear. |
08-16-2009, 04:51 PM | #5 |
Pebble Pounder Join Date: Jun 2009 Location: waretown,nj
try running them the way they are and if you dont like them cut them in so it is all triangles
08-16-2009, 04:56 PM | #6 |
Tires negate what foams work. Cutting foams,IMHO,is overated. Picking the right foam for the right tire is key. They all do a little different with different tires and weight set ups.
08-16-2009, 05:35 PM | #7 |
Rock Stacker Join Date: Jan 2009 Location: Toledo
If you cut them do so in the star pattern. You would be better off using the right foams and the right tires but if you are stuck with what you have you could try the star pattern first.
08-16-2009, 07:08 PM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
I use the Proline 2 Stage and they work rather well.
08-18-2009, 03:49 PM | #9 |
im running imex rubicons
08-18-2009, 05:21 PM | #10 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
