Which speed controller? Hello guys :) I recently got hold of a tamiya clod based crawler.It needs twin motors and a twin motored esc.I was hoping to fit 55T motors but which is the cheapest twin motored esc to buy? Cheers :) |
If you are going to run dual 55T motors, then you don't need an ESC that is specifically designed for dual motors. Any ESC that can handle the amp draw of a single 27T (stock) motor will do the trick. The Castle Creations Sidewinder would work well for your setup. |
i am running a single rooster crawler just wire up the motors so it runs on the single speed control if you don't want to mess around with two |
it seems like the new hot ticket is the FXR |
