08-14-2009, 12:02 PM | #1 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
| What are the benefits of BTA?
Like the title says, what are the advantages and disadvantages of BTA setups? I know you get a bit more clearance in front and (for most angled knuckles), you get more toe-outish ackermann. Are there other benefits? Is BTA important in a comp rig? |
08-14-2009, 12:10 PM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The obvious advantage of BTA is nothing to hang up on rocks except the axle itself. It does take some more work to get it right, as you are dealing with much less room to run tierods, etc. around shock and link locations. Ackermann has more to do with what knuckles you use, and how they are set up, as opposed to just running BTA. Toe-in or out are all adjustable, just depends on what you want to do with your steering to get the best result. I have seen several excellent front-of-axle steering setups, so BTA is not totally necessary, but it does help if tierods, etc. are as high up as you can get, at least near the top of the pumpkin. It's great to have on a comp rig, but it is not a must-have.
08-14-2009, 12:48 PM | #3 |
Thanks again, Gunnar. I've been learning a lot just from reading up on your 3 builds.
08-14-2009, 01:03 PM | #4 |
Yeah this gunnar guy is pretty helpful. What he forgot to mention is that the behind the axle set up is for people who can't drive. |
08-14-2009, 01:13 PM | #5 |
08-14-2009, 01:37 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
Pros: It helps your approach angle It gives you better steering ackreman You can dig up hill easier Cons: It takes a lot of work to set up It takes a lot of your suspension tunability away Since the inside tire turns sharper you may rub on shocks |
08-14-2009, 02:50 PM | #7 | |
I will have to disagree on a few things. In your Pros list, the first line is right. In the second line, Ackermann has nothing to do with where the steering rods are located, it is what type of knuckles you run, and the degree of toe-in or toe-out you have. Dig uphill easier? I would think that would depend on how much traction you have, and how much steering you have if you are turning. Onto the Cons. It's not that hard to set up a BTA, but it does take some thought as to making room for everything, and steering capabitily of the knuckles. As long as nothing is rubbing too much, shock tuning should not really change. Moving your shocks will get get you more steering angle, Ackermann knuckles or not. If you can't move the shocks, then that or hitting the links will determine your max steering angle in most cases. Last edited by gunnar; 08-14-2009 at 03:00 PM. | |
08-14-2009, 10:08 PM | #8 |
With the Ackermann, I think it doesn't make a difference if you're running 90-degree knuckles (0 ackermann). But for most knuckles (like the AX10 kit knuckles), with the normal (in front of axle) steering, the outer wheel turns more, while with BTA, the inner wheel turns more. I think that's what he meant. |
08-15-2009, 04:25 PM | #9 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
For me it was getting the servo output behind the axle. Didn't like my servo hitting things. Been running plastic servo horn without problems, broke it several times when it was out front. It is a pain to get to work smoothly without rubbing anything. It can limit your link and shock options, but I have mine setup the way I like it. Also depends on what kit you get, or if you build your own.
08-15-2009, 07:02 PM | #10 |
Pebble Pounder Join Date: Aug 2009 Location: ST. George
what does bta mean?
08-15-2009, 07:07 PM | #11 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Behind The Axle.
