08-17-2009, 10:06 PM | #1 |
Newbie Join Date: Aug 2009 Location: Snowmass Village
| ESC problems.. help !!!!!!!
i just got me a new novak rooster crawler brushed esc. i have it hooked up to a traxxas reciever and traxxas radio. ibut i cant get it to program. please help im frustrated and ready to throw the whole crawler across the room. thanks for any help on this! i hold the set button down, turn on the esc and wait for the red light to come on. but after that i cant get it to program where the green light is suppost to turn on. the servos make no noise or movements. ive tried diffrent ways with the wires and nothing. thank for the tips though.
Last edited by madsquirl; 08-18-2009 at 03:57 PM. Reason: servos make no noise. nothing movies. i just turn the esc on with the program button pushed. till the red light comes on. |
08-17-2009, 11:10 PM | #2 |
Pebble Pounder Join Date: Apr 2009 Location: Dallas
Explain! NO power? Do the servo still work? Can you turn the radio/receive on with out the novak in? Check for lose white or red wire! See if you swich chanels if it changes anything? |
08-18-2009, 09:28 AM | #3 |
Rock Stacker Join Date: Oct 2005 Location: Greeneville,TN aka BFE
you can always take the easy way out and take it to your nearest hobby town and they usually will do it for free
08-18-2009, 10:13 AM | #4 |
Are you sure that the ESC is properly plugged into the Rx? If not, try turning it around...
08-18-2009, 10:19 AM | #5 |
Quarry Creeper Join Date: May 2009 Location: brentwood
please tell us more, does it do anything? like the other guy said, does the servo move or make noise? Is the connector installed correctly? have you thoughly read through all instructions? give us as much info as you can, It will be much easier on all of us
08-18-2009, 10:22 AM | #6 |
| Actually, that brings up a good point. Over the years I have owned a few Novak ESCs and EVERY single one of them had incorrect programming instructions. Your best bet, if you have everything properly installed, is to call Novak support. They'll help you out. They also know about the instructions problem... |
08-18-2009, 09:37 PM | #7 |
thanks alot every one got it worken
08-19-2009, 04:25 AM | #8 |
What was the solution??
08-19-2009, 05:45 AM | #9 |
Pebble Pounder Join Date: Aug 2009 Location: My House
i dunno when i got my sidewinder, my hobby store person attached a trx plug fo rfree
08-19-2009, 12:32 PM | #10 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
08-20-2009, 02:16 AM | #11 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
Both me and my friend had roosters. And it both met the same fate. A hard hit against the wall. User error? maybe, But it was worth seeing it hit the wall.
08-20-2009, 02:39 AM | #12 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
If your only getting a green light after proper programing!! your not using the forward and reverse throttle properly during the program sequence. A solid Red LED light indicates neutral and now it has been properly programed.
