08-22-2009, 03:06 AM | #1 |
Newbie Join Date: Aug 2009 Location: wales uk
| new motor brake in
Hi all justs got a pair of integy v10 mod turbos 55t motors for my jugg and wanted to know if they need brakeing in at all i think ive seen a vid some wear about wet brake in with distilled water is this right? Also they have timing adjustments whats all that about? |
08-22-2009, 08:24 AM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
08-22-2009, 08:31 AM | #3 |
I wouldnt recommending dipping this motor for breakin, youll take the chance of ruining the bearings in it. Dipping was better for motors with bushings. If you do just be sure to spray the bearings out after with some electronics cleaner and be sure to re-oil them. |
08-22-2009, 09:26 AM | #4 |
Quarry Creeper Join Date: Jun 2007 Location: Tucson
Motor break in 1. Open motor 2. Install in crawler 3. Plug in all componets 4. Run Motor is now broken in. Were crawling here any extra bit you get from the other motor break-in's really will not make any difference here. I really do not think it makes a difference any of the RC world. Well may be drag raceing. |
08-22-2009, 10:05 AM | #5 |
RCC Addict Join Date: Jun 2008 Location: Fresno
to break in motors i was always taught to run the piss out of em w/ 2 full packs. flush it out w/ motor cleaner then reoil the bearings
08-22-2009, 01:08 PM | #6 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
On the much larger industrial motors that I have seen they (and they are internally lubricated by their own oil pump system) they always run them at half for about 10 minutes, then drain oil, clean, refill oil and repeat that max for about 20 minutes... On smaller motors such as we use, I have always unpacked them, cleaned them with electric motor cleaner, then oiled the bearings myself so I know it was done, then run the piss out of them for a full pack. Clean, inspect brushes and com, reset anything thats out, then re-oil and am good to go... I have never had any problem with a motor lasting a long time. |
08-23-2009, 02:39 AM | #7 |
THANKS ALL |
08-25-2009, 05:36 PM | #8 |
Quarry Creeper Join Date: Sep 2008 Location: tucson
i broke mine in water there working fine
08-25-2009, 05:58 PM | #9 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
I always just drop them straight in the truck but, I know a few carpet racers that will drop the motor in a bowl of caster oil (fully submerged) then run it at 2 volts for about an hr. They claim that it helps to seat the brushes and oil the bearings giving them the slight edge they need... Personally I think they are full of it but hey, what ever works. Water method was good years ago when motors were bushings (as described above). The idea was similar to the oil method in that it seated the brushes without wearing them. |
