08-25-2009, 06:24 AM | #1 |
| Need input before I spend money
I'm working on this project: Project: Rock Face txt-1 I did some side work last night and want to order parts today. I have settled on an R2HD tranny, but am still up in the air on battery\motor combo. I am thinking a 45t motor with 3s lipo, but would like some experienced input before I spend some hard earned cash. |
08-25-2009, 07:17 AM | #2 |
That's a good looking project! It's good to see folks still using the TXT axles for builds. I run a TXT super and when I initally built the truck, it had a Stampede tranny and a 55T lathe motor with a 7cell NiMH battery and the truck performed terribly. The motor did not have enough torque and almost NO wheelspeed. I recently swapped in a 10T puller and 3S lipo and the truck is incredibly fast! I will soon be installing a set of 4:1 diff gears (in place of the current stock 2:1 gears) made by Egressor and I think that will be a perfect setup for this truck. I'm not sure if this helps, because the tranny gear ratios are probably not the same, but it should give you an idea on where to start. |
08-25-2009, 07:33 AM | #3 |
I have already ordered the 4:1 axle internals from Egressor and have been tossing around the idea of a Holmes 10t puller, but they are pricey. I want to get it running first, then maybe upgrade to that. An brushless out runner is also an oprion, but I have no idea which to choose there. |
08-25-2009, 07:39 AM | #4 |
Well, I run the Astroflight 10T puller, not the HH. Either should have the power and torque that you need....especially with the 4:1 gears!
08-25-2009, 08:47 AM | #5 |
Thanks, I'll look into that!
08-25-2009, 09:09 AM | #6 |
The 10t are more than I want to spend right now, but surely can see it as an upgrade path. For now I want to get it running, the tranny and lipo will eat a good chunk of available budget. How about the Integy 35t? It should give more wheel speed, will it hold up to 11.1v? and will it be enough motor to power this rig? I have a single Monster Maxx Pro 19t 550 can right now, so I have a motor, just not an ideal motor. A 10t brushless puller or 10t holmes puller certainly look ideal, but that will have to wait for the holidays. so, 35t or 45t on 3s or stick with the Monster Maxx I have until I can get a 10T? |
08-25-2009, 09:24 AM | #7 |
I would say a 45T handwound out of your current options...that MM wont have the torque you need.
08-25-2009, 09:50 AM | #8 |
| Thanks. The 45t are cheap enough and will get me running. I do not plan on doing comps, just playing around, so it should hold me over until I can swing a 10t, thanks for your help of a confused noob. |
08-25-2009, 12:58 PM | #9 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
i think you will be very happy with a 45t on 3s!
08-27-2009, 07:00 AM | #10 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
some dyno results | |
