09-07-2009, 07:24 AM | #1 |
Pebble Pounder Join Date: Feb 2009 Location: Highlands Ranch, CO
| Shock Setup Question
OK, I've got a question on my shock setup that seems like it should be obvious but I can't figure it out. :? I've been running with my shocks internally limited 0.5" and a ride height of 2.75". The problem is that at full extension I was only getting about 3" of belly clearance. I removed the internal shock limiters and added 0.25" limiters to the outside of the shocks. My ride height is still at 2.75" but my full extension is about 3.75". So far, all seems good... The problem is that at full extension, the shocks get too long for the springs. So, the spring "comes loose" and then under compression needs to settle again. I haven't paid close enough attention to other's rigs to know if this is normal, but I'm guessing it's not. I tried moving the shock collars down to better contain the springs but then I get too high of a ride height (about 3.2"). I guess I'm looking for the best of both worlds here: a medium ride height and a lot of extension for break-overs. Here are some pictures. Any advice is welcome. At rest Full extension Close up of the spring at full extension - notice the gap Another shot of the shock at full flex Thanks EXW |
09-07-2009, 07:53 AM | #2 |
Rock Crawler Join Date: Feb 2008 Location: UK
Softer springs will let the truck sit lower. You can then adjust the collars downwards to get the correct ride height, which should keep the springs under pressure at full droop. You could also try fitting the shocks more upright - move the top mount forwards. You'll get less shock movement for the same wheel movement. Last edited by clockworks; 09-07-2009 at 07:56 AM. |
09-07-2009, 09:12 AM | #3 |
Newbie Join Date: Sep 2008 Location: Ar
the limiter outside the shock will only keep the shock from bottoming out
09-07-2009, 07:03 PM | #4 |
Thanks guys. I ended up moving the shocks in one on the chasis so they are more laid down. I then threaded the shock collars down and put 0.5" external limiters on the shocks to keep the articulation about 50 degrees. This gives me a ride height of around 2.75" and a full extension of almost 3.5". Took it for a test drive and it seemed to work. |
09-08-2009, 02:17 AM | #5 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
You could also try fitting the shocks more upright - move the top mount forwards. You'll get less shock movement for the same wheel movement.[/QUOTE] Yep! That's right |
