09-10-2009, 11:16 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Bay Area
| Need your input - Scaler or Crawler?
OK, so I got an AX10 RTC a few weeks ago and I've been looking at some build and picture threads of scalers as well as some videos and right now I'm kind of regretting getting the AX10 and not the SCX10. Now I've been thinking about getting the TCS X-Trail chassis and swapping everything over. However, I'm not sure if this is a good idea... Is the TCS X-trail worth it? Also, how good is it at crawling? I understand it won't be as good as the AX10, but relative to the AX10 how good is it? Also, is the X-trail meant for 1.9" tires or 2.2's? I'd have to use the 2.2's for now but would that be something I'd have to change eventually? I'm really on the fence about this because the X-Trail is $40, and my friend has offered to sell me saddle packs and battery plates for $40 as well and if I get one, I don't need the other, so... just want to hear both sides. Thanks. |
09-11-2009, 02:00 PM | #2 |
I am building a X-Trail right now, it is a good chassis, get the hardware that goes with it. The biggest problem is a lack of scale bodies. Most of the really good scale bodies have a short WB. If I do this again I'd likely go with a SCX10 or Tamiya chassis. The SCX because its chassis is C-channel and the Tamiya for all of the great scale hard-bodies you can get for it. Hope this helps. |
09-11-2009, 02:20 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: Canton, Jawja
Im in the same boat...kinda. I have a ax10 ARTR with alot of time and $ in it, and use it a good bit. but ive also just bought a scx10 roller off here and am waiting on some parts to start building it. once I get it running and whatnot, I'll probally play with it more than my crawler.... I say if you can, do both. Two different worlds if you ask me. |
09-11-2009, 03:33 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
You would not have started this thread unless you wanted the scaler. You already have an ax10 but it sounds like you would rather have the scaler. I would get an scx10 chassis from TCS. There about 60 bucks. Alot more options are coming out for scale trucks and as far as capable I've seen some amazingly capable scale rigs.
09-11-2009, 03:44 PM | #5 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
i'm a wicked X-trail nut. just go for it, be sure to get the hardware kit with it. it's just easier on you in the long run. here's mine. Meet the Crunko <--------- |
09-11-2009, 05:50 PM | #6 | ||
I don't want to buy the SCX chassis because its WB is even longer than the X-Trail's and that limits the bodies even more, and buying a Tamiya is out because I don't have enough money to buy another car but if I were to do it again I'd probably get a CC-01 or something. Quote:
I want to get the TCS chassis instead of the SCX because it is cheaper and has an adjustable wheelbase. Finding a body is going to be the hard part... | ||
09-11-2009, 05:52 PM | #7 | |
Also, are those 1.9's or 2.2's in that pic? Eventually I'd like to put 1.9's on there but I want to see what it looks like with 2.2's since that's what I have right now. Also, the Tamiya Hilux bodies are $50 for a complete set. May have to go Lexan for this body... | |
