09-16-2009, 09:18 AM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: ST. George
| Why droop suspension
Why is a droop suposed to work better then sprung? I see these springs http://rcpcrawlers.com/product.php?p...0&cat=0&page=1 and I think for 10 bucks why not try it out? |
09-16-2009, 01:54 PM | #2 |
Who says it works better?
09-16-2009, 01:55 PM | #3 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Droop doesn't necessarily work better. It is just something else you can try out. It's not something that everyone likes or dislikes. Like many things in crawling it's just a personal preference. Droop will get your center of gravity lower. You place the spring inside the shock body, underneath the piston. This reverses the normal shock position. So when at rest, the shock is in the normally compressed state. The thing to watch out for is during climbs the front shocks will tend to unload, causing the CoG to raise and the front will not grab as well. That is where the testing and tuning will come in to suite your needs. |
09-16-2009, 09:52 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Sorry to thread steal, but I am trying to 60/40 droop some axial shocks. Can anyone walk me through it? |
09-17-2009, 04:45 PM | #5 |
Newbie Join Date: Sep 2009 Location: Sylvania
again not to thread jack but do people use a combination of droop and spring over shocks? like a larger droop style in the rear and a normal style in the front?
09-17-2009, 06:07 PM | #6 |
Quarry Creeper Join Date: Feb 2008 Location: Bay City
Ive been useing a 75/25 droop for 2 years now and Ive been happy with it.
09-17-2009, 06:35 PM | #7 |
Quarry Creeper Join Date: Nov 2008 Location: Orange
i run full sprung on my swx. but droop on my bastard jr. but lower cg cleaner look sometimes smother |
09-17-2009, 07:27 PM | #8 |
Newbie Join Date: Sep 2009 Location: s.e. michigan
i tried it on my ax10. it worked better than the kit stock settings. but i couldn't stand the torq twist. so i started testing new outer springs and got it working better than droop with less twist.
09-17-2009, 07:29 PM | #9 |
Rock Stacker Join Date: Jun 2009 Location: USA
Tried it on my Losi MRC, worked better than stock for sure.
09-17-2009, 07:39 PM | #10 |
how do you do it.
09-17-2009, 07:41 PM | #11 |
Replace the outside spring with one on the inside of the shock body, I used a BIC pen spring myself for my little Losi.
09-19-2009, 07:02 PM | #12 |
i didnt use any springs on my droop setup. just 80wt with #1 pistons. and fuel tubing inside and out to limit travel.
09-19-2009, 07:36 PM | #13 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
I've been using 150wt fluid in aluminum bodied axial AX10 shocks and am very happy with it (on a shaft rig). It will unload at times but seems to be a happy meduim for my driving style. I am running 60/40 link set up also with it.
09-19-2009, 08:12 PM | #14 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
I use 1000wt oil in my stock axial shocks with hardware store springs under the piston inside. I also use one stock rubber spacer outside the shock to get my ride height where I want it. I tried many different weights oil and spring rates until I got it how I like it. Another thing to consider is converting to 4-link. It allows you to change the geometry to create more pro-squat. But thats another thread.... |
09-19-2009, 10:36 PM | #15 |
I know how to fully droop the axial shocks, I ran them on my tag chassis, but how do you do a 60/40 droop
09-19-2009, 11:08 PM | #16 |
09-19-2009, 11:53 PM | #17 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
I run a 80/20 droop setup w/heavy oil and inner springs. i really like it and won't go back to a full sprung setup again,it makes for very realistic suspension movement and it's fun to watch it cycle. Torque twist is easy to control as well,do a search on the topic and you'll find at least 4 threads of tech info. |
