09-16-2009, 06:41 PM | #1 |
Pebble Pounder Join Date: Sep 2009 Location: Dallastown
| Good setup?
I am thinking of getting a Axial artr Tekin fxr motor combo Hobbico cs-170 servo re using my Jr xr3 radio re using my nimh batteries (for now) or should I get the Axial rtc alum Links Hardware kit or upgrade parts as needed I also have a chance to get a mini rock crawler w/ extra body and 2 extra sets of wheels and high clearence links for $150 What would you guys do ? any improvements or changes? |
09-16-2009, 07:03 PM | #2 |
Newbie Join Date: Aug 2006 Location: Pittsboro
artr is the way to go
09-16-2009, 07:14 PM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
The top one |
09-16-2009, 07:21 PM | #4 |
does that seem like a pretty good setup and what about the losi is that a good price? I just found Axial Scorpion with CKRC updates Losi Rock Claws on Proline rims, Novak esc and motor, Hitec servo, Futaba radio, Lipo batt, Proline Rockstar body for $300 maybe this even better depending on the specs of the esc and motor and stuff ??????? |
09-17-2009, 08:29 AM | #5 |
The top one:-P
09-18-2009, 04:51 AM | #6 |
Newbie Join Date: Sep 2009 Location: s.e. michigan
if your old nimh are sub-c size plan on swapping them out for something smaller. if you want to stick to nimh go with the 2/3a size cells. but if you want the best get a 1100-1300 lipo i got mine for $20. and mount it on either the front axle or front top link.
09-18-2009, 03:50 PM | #7 |
thanks I do have sub c packs, It has a servo relocation bracket and the lipo mounted next to the servo on the axle If I use nimh packs I can mount them there correct as long as there are the smaller ones or use lipos
09-18-2009, 04:08 PM | #8 |
Quarry Creeper Join Date: Sep 2007 Location: Colorado Springs
I started with the 2/3a split pack. When I switched my chassis to a DNA Slingshot the front servo mount was made for lipo's. So instead of buying all new bateries I re-shrinkwrapped the batteries together into one hump pack so they would fit. You could also just electrical tape them together. I havent seen a Nimh pack for a crawler that wasnt a split saddle pack. I may be wrong though.
09-18-2009, 07:01 PM | #9 |
yeah split 2/3a om axle will work but for $20 you cant beat lipo (if you have charging capability
09-18-2009, 08:17 PM | #10 |
I dont have a lipo chager. I just got back from the lhs and like the triton. It sells for 129 so for now I think I am going to run the nimh untill my wife buys something then she wont be to mad when I spend more$$$. When you say 2/3 what do you meen. I saw they have a 6 cell split in half stacked and also a 7 cell nimh
09-19-2009, 01:57 AM | #11 |
Pebble Pounder Join Date: Sep 2008 Location: Carlsbad, SoCal
the 2/3a refers to a smaller cell battery. it's the same type they use in mini's(like 18th scales). Here's a link to the maxamps 2/3a packs. they aren't the cheapest, but gives you an idea what you're looking for.. http://www.maxamps.com/products.php?cat=80 |
