Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Im getting a axial ax10
Old 09-17-2009, 07:25 PM   #1
Default Im getting a axial ax10
I just made a deal for a
ax-10 was the kit version
rooster crawler esc
novak 55t motor
ckrc stage 2 suspension
futaba 3pm-fm radio
hitec 645 servo
Losi Rock Claws
Proline beadlock rims
ckrc body
lipo battery
all for $250 Is this a deal
bergy is offline   Reply With Quote
Old 09-17-2009, 07:52 PM   #2
Not bad. Now you can build it the way you want it.
THE PARTS GUY is offline   Reply With Quote
Old 09-17-2009, 08:02 PM   #3
Not too shabby.
Id look around for a MOA setup though you might like it better.
DRock9 is offline   Reply With Quote
Old 09-17-2009, 08:18 PM   #4
im just starting in the crawler scene. I think the axial is the way to due to all the parts available, We also have a redcat super crawler MOA we play around with. It craws pretty good for what I want.
Old 09-17-2009, 09:12 PM   #5
The only thing I see wrong with that is the radio. It is a good radio, but trying to set up the 3rd channel for anything other than 2 position is a bear.
Nice to see someone going for the kit. The build is pretty straight forward, if this is your first build I recommend putting everything together per plans, then put on your after-market parts.
You shouldn't need any, but if you need any help just ask (after doing a search, of course).
Greatscott is offline   Reply With Quote
Old 09-17-2009, 09:26 PM   #6
Can't go wrong with the Axial, they are beasts.
Old 09-17-2009, 11:04 PM   #7
Default Ax10
You got yourself a good deal there.
fernando is offline   Reply With Quote
Old 09-18-2009, 03:54 AM   #8
this is used so the kit is already together and I also have a jr xr3 if later I want the 3rd channel I will switch radios
