04-26-2006, 07:29 AM | #61 |
Quarry Creeper Join Date: Apr 2006 Location: the creek
| so are you running like a gp1100 12 pack then? I think the 10 pack of 3300 sub c is a great deal (around $28 after shipping). And they are separate, so you can solder how you like. I was thinking maybe a front and rear 5 on the axles to distribute the weight better. |
04-26-2006, 09:37 AM | #62 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
No, I am running AA because they are lighter. You can get some AA in 2500 mah the subC are fine and will save some weight over stock batt (weighs 3 pounds) My batt I think weighs 1 pound and li-po are not much lighter. I basically took the approach to get the max mah for the lightest package. |
04-26-2006, 01:17 PM | #63 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I got a ac dc pirhana, What would I charger it at 820mah and what voltage? I can only do up to 8 cells which is 9.6v battery and this is 12v? sorry for be confused im use to real rcs and if my walmart has one for 49 Im taking it to our property |
04-29-2006, 11:49 PM | #64 |
Newbie Join Date: Apr 2006 Location: NY
| Charging SLA batteries
Hey folks. I just wanted to share some info I've been collecting. My Nylint 1:6 Jeep is fun but battery life is an issue. I think that the batteries are OK but the charge times are just horrible. What I found was that companies are cheap on the chargers to keep their margins low. Consequently, my Nylint Crawler says the 12V battery charges in 8 hours. Oddly, the spare battery and charger (with duplicate specs) has an instruciton manual that says 12 hrs. I did some digging and finally found a website that was tailored for Quick charging of (SLA) Sealed Lead Acid batteries. It looks like the type of battery used by the nylint is more like a scooter or power wheels device than your standard RC cars that run on NiCADs. Here's the info: >http://www.powerstream.com/Scooter.htm has the EA1046(51) which will charge that battery in >about an hour and a half. You would have to figure out how to connect this to the battery, it has >a barrel connector as it is shipped. A pro grade charger with a charge time of 1-1/2 hrs copared to 8-12hrs sound real nice. Now I need to figure out if its worth $69 + shipping to me. Here's the tehcincal details that gave me confidence in their site: How to Charge Sealed Lead Acid Batteries ... http://www.powerstream.com/SLA.htm |
04-30-2006, 12:01 AM | #65 |
12 Volt 3 Amp $68.75 Kinda expensive, but if you find out a why to make an adapter im in Last edited by TLTCrawlin; 04-30-2006 at 12:05 AM. |
04-30-2006, 09:06 AM | #66 |
check on ebay for nimh 3300, you will see a 10 cell pack (not soldered together yet). you can get a charger that will charge 5 cells and create 2 packs that link for the truck. the 3300 will give you close to 1hr runtime I would bet! floog, how long are your AAs lasting? the key to a new battery is weight and dimensions I would say. you can really do a great TT with nimh batteries, or even nicad if you wanted. the sealed lead acid are just too bulky and way too heavy. |
05-11-2006, 05:49 AM | #67 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
i like my stock battery and it lasts forever unfortunatly its heavy but reliable
05-11-2006, 08:48 AM | #68 |
| Actually, I am working on a mod to still use the stock battery. It will simply move it forward and lay it down so you will get a nice tummy tuck. It will be similar to a lot of the stick builds really. I just need time to work on it is all! |
05-11-2006, 08:53 AM | #69 |
| sorry to burst your bubble but this is a lead acid battery and i dont think it should be permantly mounted at an angle.!!!! FYI like a car the battery needs to be mounted up but i could be wrong. |
05-11-2006, 08:57 AM | #70 |
my buddy just said that as long that it is a sealed lead acid battery you could mount it upsidedown and it wouldnt matter. WORD OF THE WISE |
05-18-2006, 06:30 AM | #71 |
Newbie Join Date: Oct 2005 Location: Atlanta
Mine seems to like the 3 lb. battery better. More flex when it is sitting at proper weight. It can pull me across the garage in a wagon so I am not worried about power loss due to weight.
05-21-2006, 05:39 PM | #72 | |
| Nylint DIET (now lipo) Quote:
05-25-2006, 05:25 AM | #73 |
Newbie Join Date: May 2006 Location: Cleveland
Anyone got info on the Fast and Furious battery pack that I am seeing talked about? I think that is the route I want to go when I do my tummy tuck.
05-25-2006, 11:12 AM | #74 | |
RCC Addict Join Date: Jul 2005 Location: Provo
05-25-2006, 02:36 PM | #75 |
So is the C cell battery pack the way to go then? With what I want to do the stock battery won't fit.
05-27-2006, 11:07 PM | #76 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| baterys
one of my chargers stays red always and one is green some times and red some times.They always charge. I do recomend a long slow charge.
05-28-2006, 07:41 AM | #77 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
if you are going to build a sub-c pack, make sure you dont charge it with the stock charger... i would put 6 cells on the front axle and 4 on the rear...... my F&F battery hasn't let me down yet though, and it fits perfectly inside my chassis |
05-29-2006, 12:27 AM | #78 |
Newbie Join Date: May 2006 Location: Springtown
| Laptop Batt in stick??? How do these number sound for a stick with 4wheel steering? Capacity 118WH (8000mAH) Dimension Length: 7.8"(20cm) Width: 4.4"(11.2cm) Depth: 0.9"(2.2cm) Weight 2lb (895g) Charging Time 5.5 hours (from fully discharged battery) Output Voltage 14V-18VOutput Current 8A max Battery Gauge Five stage power level indicator LED AC Charger Input 110V-240V AC AC Charger Output 16.8V DC, 1500mA This is from an external laptop batt. |
05-29-2006, 09:50 AM | #79 | |
05-29-2006, 10:09 AM | #80 |
How about removing 1 or 2 cells?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/newbie-general/20015-definitive-1-6-battery-thread.html | ||||
Scale 4x4 R/C -> nylint crawler | This thread | Refback | 02-16-2013 07:31 PM |
