05-29-2006, 10:46 AM | #81 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
laptop batterys are Lipo if i am not mistaken...
05-29-2006, 10:51 AM | #82 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
Yes, I assumed it was a li-ion when he said lap-top. Not sure how many cell it is though. Either way a 3S works good on the 1/6 scale (soon to try 4S)
05-29-2006, 02:14 PM | #83 | |
Newbie Join Date: May 2006 Location: Springtown
| What about 11.1 Volts?
A lot of the laptop batts are 11.1 volts and many are 4400-8800mah Quote:
05-29-2006, 02:27 PM | #84 |
nylints wont run on 11.1 volts....or at least mine wont, i tested it one day after it started surging from a low battery and it was putting out like 11.35 volts and already surging.....
05-29-2006, 03:45 PM | #85 |
That's strange, I just converted mine to 3S and surges at exactly 10.5 volts. It works perfect as my LCV :-P . I figured a 4S may be overdischarged before one realised it.
06-04-2006, 07:47 PM | #86 |
| Anyone use D cells? 10,000mah
I found some D cells that are 10,000mah and 1.2V X 10 for a total of 3 3/4 lbs which is about the same as stock but 2 1/2 times the runtime. Is the runtime worth the weight and space on a custom chassis?
06-04-2006, 07:51 PM | #87 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
wow, how much does something like that cost, i guess it may be worth the weight...but where would you put it, it would be huge. -Dalton |
06-04-2006, 07:52 PM | #88 |
put 5 on the front axle and 5 on the chassis.... where did you find these? |
06-04-2006, 07:53 PM | #89 |
that's really too big i think, it would kinda kill the look of the crawler. -Dalton |
06-04-2006, 07:54 PM | #90 |
cant be any worse than mounting a F&F battery on he front axle...
06-04-2006, 07:56 PM | #91 |
yeah but the ff battery is cleaner looking than that -Dalton |
06-04-2006, 08:48 PM | #92 |
I would say it is definately not "worth the weight" then again I am using only 1700-2000 and get bored with the run-time. I like it lite. |
06-04-2006, 08:50 PM | #93 |
| link --- http://cgi.ebay.com/4-Pcs-D-Size-100...QQcmdZViewItem eBay # 9735439601 9 D-cells are about the same size as the stock batt. I can drop 10 in place of the stock batt in the stock chassis and still snap the body on with no problems. Just need a way to connect them and still be able to charge them. |
06-04-2006, 09:59 PM | #94 |
| 5000mAh c - cells :) |
06-05-2006, 03:12 PM | #95 |
that would be the better way to go in my opinion -Dalton |
06-10-2006, 08:05 PM | #96 |
Newbie Join Date: Apr 2006 Location: Joliet
Anybody just try dropping in 2 six cell packs yet??? I have 2 coming, but I don't want to fry the boards but I really don't want to make a pack out of them lol.
06-11-2006, 10:24 AM | #97 |
I have an old circuiboard that is fried except for the steering turning one way, so when i get some 7.2 packs i will try it, and if it works, I will go with it on my good one...im not too optimistic about it though, that seems overkill for the circuitboard. -Dalton Last edited by hotrodzach; 06-11-2006 at 10:32 AM. |
06-11-2006, 10:25 AM | #98 |
I used 12 cells in mine for a while until I went to lipo. They were AA though. I expect it to take over 20 volts.
06-11-2006, 10:35 AM | #99 |
then i guess i will just try two 9.6 volt batteries. I really don't have much to lose since the circuitboard is already useless except for this one test. -Dalton |
06-11-2006, 01:47 PM | #100 |
there have been a couple people who ran the nylints on 14.4 volts without a problem.... 19.2 might be the death of it...... |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/newbie-general/20015-definitive-1-6-battery-thread.html | ||||
Scale 4x4 R/C -> nylint crawler | This thread | Refback | 02-16-2013 07:31 PM |
