09-18-2009, 10:37 AM | #1 |
Newbie Join Date: Aug 2009 Location: Hart
| Racking my brains out
Ok I have built a toyota hilux using the scx10 frame i have 101 mm lower links the upper is 3 link and i want to go to 4 link but for the life of me i cant figure out how to mieasure this what is the best size for the uppers and how do i measure this??
09-18-2009, 04:18 PM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: Colorado Springs
I dont know about the SCX, but I used the Boomerang 4 link kit from TCS Crawlers and the stock upper links on my AX10. Like I said I really dont know al the differences but I dont see any reason why it wouldnt work. If you are going custom on the length of the 4 link, I always set the wheelbase with the lowers and measured the length of the uppers by just setting the pinion angle where you want (I tilt the pinion up to try to eliminate as much of that angle as possible.) When you get the pinion angle you are looking for measure from there to get the upper link length. I hope this helps, I am by no means a pro at this so if anyone with better info comes along its all good. |
09-20-2009, 07:27 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I just converted an Axial rtc to four link and used 68mm upper links. That is the tube length. I used TCS boomerang on the rear and their servo mount/4 link plate up front.
