11-29-2005, 02:07 PM | #1 |
Rock Crawler Join Date: May 2005 Location: In front of my comp
| Servo ?
Will a servo rated for 130oz of torque be powerful enough to steer my TXT with 40 series moabs? thanks
11-29-2005, 02:20 PM | #2 |
Pebble Pounder Join Date: Sep 2005 Location: Canada
yes
11-29-2005, 02:30 PM | #3 |
Thanks i wasnt sure.
11-29-2005, 03:36 PM | #4 |
Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
i think 130oz is a little low. i think like 200oz and up is good
11-29-2005, 05:05 PM | #5 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
It'll be too low. You need someting much more powerful. Look for something in the much higher range, I run giant scale servos and they put out 343oz torque. The higher the better.
11-29-2005, 05:28 PM | #6 |
Maybe i should just get a 1/4 scale servo and aussies mounts, any other mounts? also today when i was playing with my TXT when i barely touch the thorttle it would kick into reverse then out should i adjust neatural ojn the TX forwarD?
11-29-2005, 07:05 PM | #7 |
Quite a few folks run Hitecs. I personally have had bad experience with multiple different Hitec's in my TXT, couldn't keep a set of gears in them as I would strip them out and I won't run a servo saver as I don't like the mushiness it creates, so a cheaper servo would end up being expensive by the time you buy replacement gear sets a few times at $20 a set. That is why I switched to the giant scale servos, these things are BEEF and there is no way you're gonna break them and at $29.99 for a servo and $4 for a gear set it's the only way to go for me on a TXT. However, they are HUGE and this may present a problem for some people, my other regular size servo that i would run in a txt and the one that I run in my TLT, and the only one I will buy from here on out is the Airtonics 94359Z. It's a $140 from Tower, I got mine cheaper from other places, but it's a brute and blows away the Hitecs, plus has a built in heat sink. After having it for awhile, I'll never go back to hitecs. Here's the link to both.... Airtronics http://www2.towerhobbies.com/cgi-bin...&I=LXCHB2&P=ML Hobbico http://www2.towerhobbies.com/cgi-bin...?&I=LXLN93&P=7 Also, check out out my thread in the TXT section "Chop, Cut, Rebuild........" You will see how big the Giant scales are. Troy |
11-29-2005, 07:11 PM | #8 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I also run the 94359Zs, but the new high-torque "Rock Crusher" should spec out a bit better.
