09-22-2009, 04:45 PM | #1 |
Newbie Join Date: Sep 2009 Location: las vegas
| new to rock crawling
i just got into crawling and i am trying to figure out what modifications i should do to my axial scorpion! please help me out |
09-22-2009, 06:34 PM | #2 |
Welcome to your new obsession!!!! The best thing to do is to search the AX10 forum for upgrades (it is always best to search before posting). The weak link on the AX10 are the Axels, they pop off easiely when under a load, to fix it you can get after-market aluminum axels or get rings for the U-Joins. I am running Traxxas axels with HR rings and really haven't had a problem. I don't beef the axels up any more than this because this is my weakest point of the drive train, it is also the easiest, quickest, and least expensive to repair. As far as the rest of it goes, you'll hear a lot of advice, I recommend you run your truck, go to a couple of comps, you'll figure out what you want to upgrade. |
09-22-2009, 10:12 PM | #3 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
Start surfing the threads! Good luck |
09-22-2009, 10:50 PM | #4 |
Quarry Creeper Join Date: Aug 2008 Location: Texas border crawlin from cops
Theres soooo maaaannnyyyy threads here regarding axial... Its depends on how much are you willing to spend.. Start using the search button.
09-22-2009, 11:55 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
I just got mine a month ago but I spent a month searching and reading on here before that so when I got it I was ready to make tweaks. In fact I had some stuff ordered before I bought my crawler. There are so many options its a matter of choice. I didn't get a chance for pics but if you search my name you will see my post and changes I made when I first got mine. I just made some more and dropped the ride height 5/8" and it really helped a lot, I was worried I went to low as it is at 2-5/8" to bottom of chassis now. Good luck and have fun... |
09-23-2009, 09:40 AM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Run it! Learn to drive! Practice! Practice! Practice! Play with springs, shocks, tire weight, link placement. Up grade what breaks and/or ya don't like. Read, search, ask questions. Go to some local comps and see what others are doing. Watch, learn, ask questions! Welcome to the money pit addiction |
09-23-2009, 02:42 PM | #7 | |
Quarry Creeper Join Date: Jul 2008 Location: Splendora
09-23-2009, 06:55 PM | #8 |
09-23-2009, 10:03 PM | #9 | |
I wanna be Dave Join Date: Sep 2008 Location: four o six
he's right, run your rig, change one thing...run it again, see what works. The first thing I would do is beef up the drivelines..cause if your broke...you can't learn what your rig can do...but you can learn how to fix it... | |
09-24-2009, 05:18 AM | #10 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
Welcome to the empty pocket club |
09-24-2009, 08:11 AM | #11 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
Small zip ties around the driveshafts hold them together pretty good for cheap. You want the tie to clamp down on the yoke part so it doesn't spread open and pop apart. Once they pop open they don't last long, either popping very often or tearing apart fairly quickly. Get some thin plastic material and make small plates, attached to the upper links with zip ties for electronics. Move batteries to the axle, or get them as low as possible. Don't forget to have fun and read everything here you can. |
09-24-2009, 12:09 PM | #12 | |
