09-29-2009, 03:51 PM | #1 |
Rock Stacker Join Date: Feb 2008 Location: Masshole
| the best crawler sevo
So I am getting ready to get back into rock crawling and what not. And my question is what should I be looking for a servo?? Its going in my project Silverado. Nothing fancy.I don't know much about them so any and all info would be great thanks. Also how about speed controls? Whats good now a days Last edited by 03ssilverado; 09-29-2009 at 04:28 PM. |
09-29-2009, 04:12 PM | #2 |
Newbie Join Date: Sep 2009 Location: Madison
Well i would definitely go for metal gears, and something around 80oz of torque or more if you want a reliable servo that can steer the wheels well. OR you can always just get a cheaper servo around 40oz of torque with plastic gears, i would honestly recommend the hitec HS-625MG or the HS-645MG they are nice servos that are cheap enough ($35-$40). OR if you want waterproof there is the traxxas servo with 80oz of torque for about $14 (no servo horns included) that i saw at my hobby shop, not sure if the gears are metal though.
09-29-2009, 04:29 PM | #3 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
if this a servo for steering - I have JR 8711 which works well and I also have a Hitec 7955tg that is also real good. I would recommend Both. They are in the 330 oz torque range which should give you plenty of power steering on the rocks. I beleive airtronics makes a high torque one too but have never used it. Hope this helps. As far as ESC's I have a castle mamba max which works well. The Tekin FXR is a bit cheaper and from what I hear has an awesome drag brake. |
09-29-2009, 04:43 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
You asked some of this in another thread but : Novak Rooster Crawler & the traxxas 2075 for bashing.
09-29-2009, 05:26 PM | #5 |
yeah that was the question I was going to ask but said servos instead Thanks for the info guys |
09-29-2009, 07:22 PM | #6 |
Pebble Pounder Join Date: Jan 2009 Location: here
300 oz plus, 645mg wouldnt even work in rock for me, maybe in grass or concrete flat. i am 7955 upgrading to 7950 |
09-29-2009, 10:55 PM | #7 |
Quarry Creeper Join Date: Dec 2007 Location: los molinos c.a.
jr 8711 403oz torque at 6v or jr z9100t 370oz torque at 6v both have metal gears and aluminum cases and fully rebuildable
09-29-2009, 11:29 PM | #8 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
Futba 9157 = 425oz |
10-01-2009, 12:31 PM | #9 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
10-02-2009, 02:43 AM | #10 |
Pebble Pounder Join Date: Aug 2009 Location: RuffNeck Build Lab.....
Good info as I am in the market for the same..........
10-02-2009, 03:31 PM | #11 |
10-12-2009, 05:47 PM | #12 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
hitech 645 works great and good price
10-12-2009, 07:07 PM | #13 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
futaba s9157 is a beast if you are getting a servo go for that one just my $.02 |
10-12-2009, 07:57 PM | #14 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Best servo ever
hitec hs 7950 th has 487 oz of torque
10-12-2009, 08:43 PM | #15 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
futaba s9175. it will move my entire car sideways instead of not moving if my tires are bound up. do a lot of reasearch on what you buy. you will find alot of complaints about the JR's and hitecs getting sloppy or needing to replace parts after a month or two. so whats suggested to everyone to fix their problem a futaba servo. im only biased because i spent a ton of hours the last 2 weeks researching servos and electronics
10-12-2009, 11:15 PM | #16 |
Newbie Join Date: Aug 2009 Location: up the hill
DUDE.... If your a pimp the only way to go is the 7950 with a castle bec wired in turned up to 7 volts that is more power then you need then you will just start ripping rod ends apart (that is super comp rig status!!!)
11-04-2009, 03:15 PM | #17 |
Newbie Join Date: Sep 2009 Location: Scappoose
Holly crap guys, the stock servo is rated at like 90 oz I think, and it is pretty weak, but aren't you guys breaking stuff at 350-400+ oz?
11-04-2009, 04:03 PM | #18 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
This is all you will need: http://www.rpphobby.com/ProductDetai...Code=HRC35645S Plenty of torque for rock crawling, without wasting your money by overdoing it. |
11-05-2009, 02:34 PM | #19 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
--->>> Why so much "beefing" around!!! | |
11-05-2009, 04:59 PM | #20 | |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
This is what I've been running, and no issues. Granted, its not a comp rig, but for bashing around it seems to do the trick. | |
