10-04-2009, 03:36 PM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Alberta
| Noob ? Axial Esc
Can I run a larger turn motor than my 55t on my stock Ax10 ESC? will I get any benifits from this? Im looking for more trq and less speed.
10-04-2009, 03:51 PM | #2 | |
If your looking for slower speeds and more bottom end power,a higher wind motor is definitely one way to get that. | |
10-04-2009, 03:55 PM | #3 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
You should be able to run a "higher" turn motor with no problems at all. More turns is easier on the ESC, less turns draws more current (power) and is harder for the ESC to run. You want to stay "above" ESC's motor limit. (Edit: Yeah what he said) Last edited by Charlie; 10-04-2009 at 04:02 PM. |
10-04-2009, 07:00 PM | #4 |
Thanks alot for the info, I tried looking for info on it but couldnt find anything. I really appreicate the help. |
10-12-2009, 05:37 PM | #5 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
yes, you cant go the other direction though. say 27 down to 20.
