10-17-2009, 01:37 PM | #1 |
Newbie Join Date: Oct 2009 Location: menomonie
| castle BEC install
I bought a bec what spot on the spectrum receiver do I plug it in and any thing else besides just pluging it in
10-17-2009, 01:53 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Splendora
You plug it in the batt slot or the bind slot which is the same slot.
10-17-2009, 02:03 PM | #3 |
Thank you,do I still have to unhook or cut the red wire from the ESC to the receiver plug.
10-17-2009, 02:11 PM | #4 |
All of this info is also on the package the BEC comes in..... http://www.castlecreations.com/products/ccbec.html# |
10-19-2009, 11:59 AM | #5 |
Quarry Creeper Join Date: Sep 2009 Location: Chico
Just to make things more confusing ;), You can also ru nthe BEC directly to the Servos. You run the 2 power outputs t othe servo power leads and then run the servos signal wire to the reciever. the signal wire from the BEC is not used in this setup.
