10-22-2009, 02:01 AM | #1 |
Pebble Pounder Join Date: Sep 2009 Location: Norway
| winch on a dx3s?
how should i connect the winch to the receiver? thinking of buying a bulldog winch from rc4wd and how does it works when connected? just need some answers before buying, so i see if its possible:-P |
10-22-2009, 03:28 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
You should get the wireless controller they sell for it |
10-22-2009, 03:39 AM | #3 |
its under consideration, but just want to know if its possible to just hook it up to the AUX channel and do some magic trick to make it work without a remote that i can loose:p
10-23-2009, 12:22 AM | #4 |
I'm not sure if you can do it with the DX3S? You really need a 3 position switch and the 3S only has a 2 pos switch. With a 2 pos it would only allow you to spool in and out and not shut off? Kinda the same prob that everyone runs into with trying to have dig with the DX3S..... And as far as the wireless controller goes for it just use double sided tape and put it on your TX! |
10-23-2009, 04:49 AM | #5 |
crap :p just wanted to save som bucks but then ill have to buy the wireless one then:p one in front and one in the back mounted in my makeshift rollcage expensive but thnx for the input
