11-04-2009, 07:15 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: lakeside
| can someone help
can someone explain the hole motor turn thing i know crawlers mostly run 45t and 55t but why and what a lower turn motor would be like crawling i'm new and learning so bear with me
11-04-2009, 07:43 PM | #2 |
Newbie Join Date: Oct 2009 Location: Ocean Springs, Mississippi
im pretty sure its because you dont really need speed you need more power
11-04-2009, 07:43 PM | #3 |
Newbie Join Date: Jul 2009 Location: North Idaho
From my understanding, higher turns = lower rpm, more torque, and uses less power. Lower turns = higher rpm, less torque, and uses more power. Still kinda noob myself, so feel free to correct. |
11-04-2009, 10:54 PM | #4 |
Quarry Creeper Join Date: Nov 2008 Location: Orange
Lower turn: longer run time slower speed less rpm smoother throtle For an ax10 i run a 35t for wheel speed and a 13tooth for the slower speeds. |
11-04-2009, 11:39 PM | #5 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
The higher the number of turns, the more torque the motor produces, but also the less all out wheel speed it can achieve. If you are wanting to simple crawl really slow on the rocks, go for a 55T. If you are wanting great all around abilities for all kinds of terrain, go with a 45T. I wouldn't go below a 35T motor for a crawler, and I would only recommend a 35T if you were going with a 3S LiPo. Otherwise get a 45T or a 55T.
