11-12-2009, 05:10 PM | #1 |
Newbie Join Date: Oct 2009 Location: Greenville
| wobbly tires
When the truck is moving, the tires don't run true. They are a little wobbly. When I grasp the tire in my hand, it has side to side play. I don't think this is right. From the videos I have watched with other trucks; I don't see any wobbling. Or, maybe I just want everything to be perfect. Considering I have dropped a lot of cash into it. 2.2 RPP Limited Edition wheels, Mud Slinger tires |
11-12-2009, 05:16 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Are the wheels sitting flush on the hex's? Are you sure you don't have a bent axle shaft? Of course they will not be super ballanced because there are small imperfections, but anything excessive means something isn't right.
11-12-2009, 05:18 PM | #3 |
Pebble Pounder Join Date: Oct 2009 Location: Perrysburg
I have had this problem if the foam is not sitting in them right.
11-12-2009, 05:57 PM | #4 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
are the tires wobbly or are the rims wobbly. if its the tires then its very common. sometimes messaging the tires to maybe seat the foam better works. If its the wheels then something is not straight or not seated properly on the hexes...........CAUTION: Messaging Tires has been know to the state of California to cause chubby's in certain Rock Crawlers. If chubby last longer than 1hr. You need to message harder.
11-12-2009, 06:27 PM | #5 |
Pebble Pounder Join Date: Nov 2006 Location: vaca, nor cal
11-12-2009, 06:28 PM | #6 |
Rock Stacker Join Date: Aug 2009 Location: LITH
Do have any wheel weights? If so are they run even in the rum.
