11-19-2009, 10:04 PM | #1 |
Newbie Join Date: Nov 2009 Location: Vancouver
| Aluminum Upgrade
What would this replace on my AX10 rtr http://www.tcscrawlers.com/Axial-Rac...2-p-17335.html and is it a good upgrade.:? |
11-19-2009, 10:06 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
its a must have up grade dose all you links and steering links and frame braces
11-19-2009, 10:22 PM | #3 |
Ok thanks, and do I require 2 of these kits because in the photo it only shows enough for 1/2 of the Crawler.
11-20-2009, 07:13 AM | #4 |
That should be enough to replace all of your lower links (two front straight, bent rears), tie rod, drag link and chassis braces. You'll only need one...
11-20-2009, 07:13 AM | #5 | |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
2 lower rear 30 degree bent links 2 lower front links 4 upper y links (f and r) 1 upper drag link 1 lower drag link 2 chassis spacers 14 spacers dont forget the RTR hardware upgrade kit http://www.tcscrawlers.com/Axial-Rac...1-p-17066.html | |
11-20-2009, 12:55 PM | #6 |
thanks
11-20-2009, 06:38 PM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Go buy 1/4 aluminum tube with an .049 wall thickness you can make your own links, I picked up 6 feet for $17. I made enough links for two crawlers and still had 2 feet left over. Use an 8/32 tap down the center and 3/4 inch set screws to attach the rod ends and your in business. The tubing can be cut real easy with a small tube cutter and all the lenghts are listed in the Axial manual.
11-20-2009, 08:00 PM | #8 |
ye thats a good idea. Ill check out home hardware. Ill think about it |
11-20-2009, 10:54 PM | #9 |
Rock Crawler Join Date: Nov 2009 Location: bolivar mo
pcdc25, I just ordered a kit ax10. I bought the grey alluminum upgrades. I have the hardware kit and the green alluminum upgrade kit I would sell ya.
11-20-2009, 11:08 PM | #10 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
I would recommend buying 5/16th delrin. Slippery than snot on rocks and just as strong as aluminum. And the best part 5' of rod for 5 to 8 bucks
11-21-2009, 12:38 AM | #11 |
thanks scriner but no im going to try and make my own.
11-21-2009, 07:31 AM | #12 |
