12-06-2009, 03:10 PM | #1 |
Rock Crawler Join Date: Mar 2006 Location: Up North
| Open Diffs in Axial Ax10 Axles Help Want to build a hybrid buggy/rock racer rig with my left over HBZ Warthog chassis... i want to run open diffs front/rear with the ax10 axles.What parts do i need for the conversion..i seen a gear set for the ax10..is this all i would need ?.http://www.tcscrawlers.com/Axial-Dif...0-p-17547.html thanks.... |
12-06-2009, 03:19 PM | #2 |
Use WK diffs, they are built better than then the Axial diffs, they will come with everthing you need.
12-06-2009, 03:30 PM | #3 |
GREATSCOTT So you mean these right? |
12-06-2009, 03:34 PM | #4 |
| http://www3.towerhobbies.com/cgi-bin...?&I=LXPZX9&P=7 Oops forgot the link before,,,,,, Cant i just remove the lockers and add the diff gears $6 compared to $30?. Last edited by jeepster73; 12-06-2009 at 03:43 PM. |
