12-14-2009, 05:16 PM | #1 |
Rock Stacker Join Date: Dec 2008 Location: Monroe TWP
| waterproofing motor
sup guys? been a while since ive logged onto here. i have an axial ax10 scorpion. its a RTR but with a 55 turn crawler motor in it. i like to mudbog this thing all the time. i live on a farm so its pretty hard to keep away from tractor ruts and such. anyway what are some ways to prevent my motor from possibly shorting out should it end up under the water level?
12-14-2009, 05:35 PM | #2 |
Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
It wont short out, will run underwater till it gets full of dirt an gunk, then just clean it out and oil the bearings! I do it all the time but it will wear the brushes an com alot faster.
12-14-2009, 05:38 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Don't forget the electronics! There should be a sticky in this section. |
12-14-2009, 05:49 PM | #4 |
what do you mean by "wear out the com"?
12-14-2009, 06:01 PM | #5 |
| The "com" or commutator is the part that spins inside the motor, it has copper contacts on the end that the brushes ride on. mud-dirty water etc can let bits of soil or rock scratch or chip the com or brushes as the grit gets rubbed bettween the two.
12-14-2009, 06:07 PM | #6 |
P.S. if you do wear or chip the com you can remove it and have it turned down with a lathe so it has a new smooth finish, should replace the brushes as well when doing this. Any good hobby shop that does servicing "should" have a com lathe an be able to do it for ya cheap (we only charge $5 at our lhs)
12-14-2009, 06:08 PM | #7 |
oh ok gotchya. so how do i take the motor apart and clean it? or so i just run like warm clean water through or smething like that?
12-14-2009, 06:16 PM | #8 | |
But then when u get home, take the motor out, pull out the brushes and unscrew the 2 philips head screws on the back of the motor. Then you can pull the back off and then pull the com out, clean and reasemble | |
12-14-2009, 06:17 PM | #9 |
To begin with, just spray the motor out with WD40 after you run it. When you start noticing the motor doesn't have the power it used to, then you will want to worry about opening it up for service. It really all depends on conditions, sometimes you won't need to do anything for months, other times you it could be a few runs before it needs it.
12-14-2009, 06:24 PM | #10 |
Donkey Punch Champion! Join Date: Oct 2006 Location: Minneapolis
...soak everything in a thin layer of Super Glue. Seals it all up well.
12-14-2009, 06:24 PM | #11 |
tru but im not seeing any screws to open this motor up and take the brushes and stuff out.
12-14-2009, 06:26 PM | #12 |
| It's the stock motor that comes with the kit? If so, it's a sealed endbell and all you can do is spray it out as best you can through one of the openings if you start having trouble....besides, they are fairly cheap and could be considered a "throwaway" motor |
12-14-2009, 06:31 PM | #13 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
worst case it craps out and you goto rc4wd.com and spend $10 on a silver can
12-14-2009, 07:40 PM | #14 |
tru tru. who knew u could get a 55t for so cheap. haha. i'll buy like 5 at once so i have all those spares. haha.
12-14-2009, 07:52 PM | #15 |
lol yep, sounds like a plan
12-14-2009, 09:24 PM | #16 |
yeah definitely. haha.
