12-15-2009, 06:37 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: Sacramento
| ummm...what is EPA?
And why do I need it. I want to get a new controller and speed control, and I keep reading about the importance of EPA's and what not...please be kind to a noob and help Ashton |
12-15-2009, 06:38 PM | #2 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
End Piont Adjustment
12-15-2009, 06:42 PM | #3 |
12-15-2009, 06:44 PM | #4 |
so that would be useful for a dig servo, in having the tranny engaged, locked, or free, is that correct? And the only way a ESC effects a EPA wouls be in the determining if throttle positions? Ashton |
12-15-2009, 06:44 PM | #5 |
12-15-2009, 06:47 PM | #6 | |
They are almost essential for a dig unit. Without them you may not be able to get them to engauge properly. The esc only knows what information its given. Just because you pull the trigger all the way back, it may not be the proper signal for the esc to go wide open. The same applies for reverse/brake. Ain't no thang. | |
12-15-2009, 06:56 PM | #7 |
12-15-2009, 08:50 PM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
You can also use the EPA on your throttle channel to smooth out its response a bit. The technical term in electronics for this is "scaling". Think of it this way (using a Spektrum controller as an example): Your ESC has a fixed range of operation, zero power to full power applied to the motor. The Spektrum controller can increment or decrement the full power (or braking) endpoint in "one percent" steps. So by setting the endpoint at 125% you are allowing the full power endpoint to be incremented by a total of 125 steps. The math is 100% (real power units) / 125 steps = .8% of the total power per step vs 1% if you used 100% as your endpoint value. In electronics we say you have a "resolution" of 0.8% (per step). Conversely, if you used 80% as your endpoint the resolution would be 100/80 = 1.25% per step. Narly1 |
12-17-2009, 11:59 AM | #9 | |
Pebble Pounder Join Date: Jun 2006 Location: Sacramento, near Antelope
For example: At 100% throttle EPA, the car will go 100% of it's maximum speed when the trigger is pulled all the way. At 75% throttle EPA, the car will go 75% of it's maximum speed when the trigger is pulled all the way. | |
12-17-2009, 02:16 PM | #10 | |
It depends what value you have your EPA set to when you initially calibrate your ESC. Narly1 | |
12-17-2009, 02:26 PM | #11 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
