12-16-2009, 02:29 PM | #1 |
Rock Stacker Join Date: Oct 2009 Location: israel
| 2 Motor's from various companies, it will be ok ?
Hello. I bought bully axle and I have one motor of Novak 55t, and I need another motor.. It will be ok if I use various companies ? For example 55T of rc4wd ? one more question, 1850mAh Bettery, How long will last on bully axle with 2 motor's of 55T ? Thanks, Avi. |
12-16-2009, 02:48 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: lodi
if im right the 55t from rc4wd is a totally different type of motor and will not sync up correctly with the novak. your best bet is to pick up 2 of the rc4wd or 2 other matching motors. im running integy 35 turns with a 1500 mah lipo and get about 15 good minutes of run time from them as you are running lower turn motors im guessing anywhere from 20-45 min run times and you also have a larger mah battery then me also so this will also effect your run times
12-16-2009, 03:30 PM | #3 |
Hey pal. Thnak you for the fast answer. 15 min ? it's very little time ! for now, with one motor on T-rex60 axle, I use a 5000mHa battery, and it's good for 3 Hours ! The problem with the battery is it big size. So what are you doing ? Replace battery every 15 minutes ? |
12-16-2009, 03:36 PM | #4 |
yeah lol. i have 3 of them. also it depends on what im doing, if im doing alot of highwheel speed crawls it kills it fast so my rough 15 min time but if im just goofing off and crawling for fun and not on the clock i can easly get 25 mins out of them. but i usually swap the battery out after every comp course so i dont have to worry. my scaler with a 27turn and 3300 nimh bat gets roughly 45 mins out of it i wish i got 3 hours lol >_< i could crawl all day long on 2 batterys
12-16-2009, 04:26 PM | #5 |
Gotcha I think you need to buy two battery's of 5000 mAh and Wagon And then you can crawling all the day Amm.. I think I will buy 2 battery's of 2200mAh 2S 25C Lipo Pack, it will be great. By the way, on the way you can show me your crawler (if you want..) Avi. |
12-16-2009, 05:52 PM | #6 |
ill post all my thread when i get home from work will have to go searching for them lol but my latest one is punks light weight bully as im posting this i beleave its just a few under this thread but ill post up links for yeah
12-18-2009, 01:59 AM | #7 |
Pebble Pounder Join Date: Feb 2009 Location: CY
Can we run say a 35T up front and a 45T in the rear instead of mixing pinion gears?
12-18-2009, 03:45 AM | #8 | |
Rock Stacker Join Date: Nov 2009 Location: Europe
Using 45t front and 65t rear | |
