12-17-2009, 10:07 AM | #1 |
Newbie Join Date: Aug 2009 Location: oregon
| switching from NiMH to 3s lipo
I am running and RTC ax10 and want to switch from my 6 cell NiMH to a 3s Lipo's. I currently have a Vision Peak 2 charger http://www.dynamiterc.com/Products/D...ProdID=DYN4044 which I am assuming is no good if I want to switch. What is the most cost effective way to make the switch? BTW I am running a stock ESC, HS-645mg servo, and a stock 55t motor. |
12-17-2009, 10:44 AM | #2 |
Newbie Join Date: Oct 2009 Location: Santa Rosa
You'll need a speed control and charger that handle lipos. I have an FXR ESC and love it. It will handle 3s lipos. As for the charger, check hobbypartz.com. They have good prices and cheap shipping.
12-17-2009, 10:51 AM | #3 |
Pebble Pounder Join Date: Oct 2009 Location: Burbank CA
Here's a good place to start... Definitive ESC, MOTOR, and BATTERY threads - RCC's top tech threads! --> check out the battery thread links within. |
12-17-2009, 11:19 AM | #4 |
thanks..... one of the problems that I am having is trying to find the balance between $$ and quality. My biggest issue is the Lipo charger I guess how much do I need to spend? The FXR ESC seems to be the best and the batteries are all about the same price/quality. |
12-17-2009, 12:34 PM | #5 | |
12-17-2009, 01:28 PM | #6 |
I may also try some 7-8 cell split packs for the front axle I think that my 6 cell packs are 2400 mah does that # represent the run time on the battery? |
12-17-2009, 02:09 PM | #7 |
| Not necessarily, that speaks to the capacity. mAh stands for Milliamp Hour, a technical term for how much power a particular battery will hold. However, it can be translated as the more power the battery can hold can mean the longer it will last - EDIT: as it speaks to run time not life of the battery.
12-17-2009, 02:42 PM | #8 |
thanks |
12-17-2009, 11:51 PM | #9 |
Quarry Creeper Join Date: Nov 2009 Location: East Bay
| This might work LOSB9607 MSRP: $39.99 Available for*: $29.99 *at participating retailers Lithium Charge Converter Want to run lithium batteries for more power and longer run times but don’t want to have to buy an expensive Llthium charger? At a Glance The Lithium Charge Converter will allow you to charge a lithium battery with a charger you probably already own. Just plug a lithium battery into the charge converter, select the cell type and confirm the number of cells, adjust the charger to the correct output, plug it into the charger and start charging! The converter allows you to use a nickel-based charger to charge lithium-based batteries. No need to buy an expensive LiPo charger. Features
# Cells:2-6 LiPo and 2-8 M1 Li-ion Technical Notes Only the following approved NiCd or NiMH chargers should be used: Blaa...blaa...blaa call them up your charger might work with it.. o Dynamite - DYN4036 - Prophet Plus™ AC/DC Peak Charger o LRP – 41550 - Pulsar Competition ** o Novak – 4490 – Millennium Pro ** o Orion Avionics - ORI62200 - Advanced Flight Charger ## o Much More - MM-CTXC – CTX Cell Master V1.0 ** These chargers will not charge more than 3-cell LiPo packs ## Using the NiMH or NiCd modes |
12-18-2009, 12:17 AM | #10 |
PM Sent...
12-18-2009, 11:59 AM | #11 |
thanks.....Returned |
12-18-2009, 12:28 PM | #12 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
I ran a 4200 6 Cell in my AX-10 for a long time... then just last week made the switch to an FXR and 2C Lipo. I am still blown away by the difference! Im a firm believer in Lipo. I wont go back. Lipo from now until something better comes along! Good luck in your decision! |
12-18-2009, 12:45 PM | #13 | |
12-18-2009, 12:46 PM | #14 | |
12-18-2009, 05:59 PM | #15 | |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
JEFF | |
12-24-2009, 11:05 AM | #16 | |
Quarry Creeper Join Date: Oct 2009 Location: 707
bought an fxr, tore my old 3000 nimh in half and made a saddle pack out of it. loved the run time but I herd good things about 3s lipo's wheelspeed so i bit the bullet and went with a 2600 mah 3s lipo n wooo! no more getting jammed. 7.4v isnt enough power!! for mee... | |
12-25-2009, 08:53 AM | #17 | |
JEFF | |
