12-24-2009, 11:36 AM | #1 |
Newbie Join Date: Nov 2009 Location: Dundee
| need wiring diagram
MERRY CHRISTMAS! I need a diagram on how to wire a mamba max to dual brushed motors. PLEASE. |
12-24-2009, 05:30 PM | #2 |
can anybody tell me how?
12-24-2009, 06:01 PM | #3 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
Im guessing your not running a dig setup?
12-24-2009, 06:27 PM | #4 |
These aren't my pics but heres some diagrams i've found on this site Hope this helps |
12-24-2009, 10:24 PM | #5 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| That bottom diagram as the motor wires reversed,,,ive included the diagram i made,,for the way Bully is wired but i only have the switch that goes to the rear axle,,i have front dig only,,if you dont have dig then ignore the switches
12-24-2009, 11:11 PM | #6 |
12-24-2009, 11:23 PM | #7 |
I believe like the bottom drawing without the switches. I just wanted input before i did it and burnt something up. |
12-24-2009, 11:28 PM | #8 |
Newbie Join Date: Nov 2009 Location: Farmington
or you could sell it to me!!!!
12-24-2009, 11:41 PM | #9 |
if you arent using dig then you run the red wire from the esc to the pos on the front motor and the neg on the rear motor,,the black from the esc goes to the neg on the front motor and the pos on the rear motor,,you can wire it to one then the other or run the wires evenly from the esc to the motors,,i wired mine equally from the motors to the esc
12-24-2009, 11:57 PM | #10 |
Pebble Pounder Join Date: Dec 2009 Location: Lancaster
| Reversed motors, this would only work if motors were facing opposite directions correct? if you had car sitting infront of you and front is facing to your left, if both armatures were facing away from you the wiring would be the same not reversed(correct?) armatures facing opposite directions you would reverse polarity, yes?
12-25-2009, 12:22 AM | #11 |
yes, if the wires are soldered to both motors on the same side,,not flip flopped then the wiring should be the same,,if you wire it up and one motor runs backwards then just reverse the wiring on that motor,,if both motors are zero timed
12-25-2009, 10:07 AM | #12 |
12-25-2009, 10:11 AM | #13 |
| Ok, I'm going to wire it up like you have it stated here. I'll let you know how it turns out. THANKS, Jeremy
